Plugins
PanelCommunity
Business Text logo
Business Text
Grafana Labs
Get plugin
Business Text for Grafana
CI CD License
This project was originally contributed by Volkov Labs - thanks for all your great work!
We have republished under the same plugin ID, keeping the community signature. This means you can simply update your plugin version. A new ID would have required manual updates to your dashboards. For additional information on the changes, see the Notices.
The Business Text panel plugin allows you to construct a text visualization template from the values of a dataset returned by a data source query.
Requirements
  • Business Text panel 6.X requires Grafana 11 or Grafana 12.
  • Business Text panel 5.X requires Grafana 10 or Grafana 11.
  • Dynamic Text panel 4.X requires Grafana 9.2 or Grafana 10.
  • Dynamic Text panel 2.X and 3.X require Grafana 8.5 or Grafana 9.
  • Dynamic Text panel 1.X requires Grafana 7.
Getting Started
You can install the Business Text panel from the Grafana Plugins catalog or use the Grafana command line tool.
For the latter, please use the following command:
grafana cli plugins install marcusolsson-dynamictext-panel
Highlights
  • Uses Monaco Code Editor with automatic JavaScript code formatting.
  • Supports Markdown and Handlebars.
  • Renders markdown-it into HTML elements.
    • Supports the highlighting of code syntax using A11Y styles.
  • Provides code sanitization:
    • HTML inside templates is sanitized using XSS.
    • Can be disabled in the Grafana configuration through the disable_sanitize_html parameter.
  • Supports display of nested objects using the {{json object}} Handlebars helper.
  • Supports display of time global variables (__to and __from) as seconds, ISO timestamps, or formatted using the dayjs library.
  • Supports adding the Handlebars helpers and event handlers.
  • Supports adding CSS styles with dashboard variables.
  • Supports internationalization using custom helpers.
Documentation
Section Description
Rendering Explains how to create a visualization template for your data
Recipes Useful snippets that you can use in your templates
Features Demonstrates panel features
Release Notes Stay up to date with the latest features and updates
License
Apache License Version 2.0, see LICENSE.
Insights
  • Adoption
    Running on 128,574 active Grafana instances.
  • Activity
    Last updated 3 Nov 2026.
    3 releases in the past year.
Version
6.3.1
Dependencies
  • Grafana >=12.3.0
Developer
Grafana Labs
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
