Plugins 〉Hubble Process Ancestry
Hubble Process Ancestry panel plugin for Grafana
Grafana panel plugin that allows to visualize Hubble Process Ancestry directly in Grafana interface. It requires Isovalent Cilium Enterprise.
Requirements
A compatible Grafana datasource plugin is required for this plugin to work. Currently there is Hubble datasource plugin available.
Usage
On dashboard that supposed to show process ancestry add variable "Pod" that fetches pods list from datasource plugin.
Add panel plugin on dashboard by searching visualization "hubble process ancestry", selecting appropriate datasource plugin, "Process Ancestry" query type and "${Pod} = ..." value in "Pod" dropdown.
Data schema
Currently two data frame types are supported: for PROCESS_EXEC and PROCESS_CONNECT events.
PROCESS_EXEC
| field | type | sample |
| node_name | string | minikube |
| time | number | 1675087549022 |
| kind | string | PROCESS_EXEC |
| id | string | minikube/1675087549.22000000/PROCESS_EXEC/bWluaWt1YmU6MjA2NjkwMDAwMDAwOjIzMTU2 |
| process/exec_id | string | bWluaWt1YmU6MjA2NjkwMDAwMDAwOjIzMTU2 |
| process/pid | number | 23156 |
| process/uid | number | 23156 |
| process/cwd | string | / |
| process/binary | string | /minio-operator |
| process/arguments | string | |
| process/flags | string | procFS auid rootcwd |
| process/start_time | number | 1675087549022 |
| process/auid | number | 0 |
| process/docker | string | 97b5d10913ddc80e4409e715f0c73e2 |
| process/parent_exec_id | string | bWluaWt1YmU6MjA2NjMwMDAwMDAwOjIzMTMy |
| process/refcnt | number | 0 |
| process/pod/namespace | string | minio |
| process/pod/name | string | minio-operator-5f4cb79d7c-6rzr6 |
| process/pod/labels | string | k8s:app.kubernetes.io/instance=minio-operator,k8s:app.kubernetes.io/name=operator,k8s:io.cilium.k8s.namespace.labels.kubernetes.io/metadata.name=minio,k8s:io.cilium.k8s.namespace.labels.name=minio,k8s:io.cilium.k8s.policy.cluster=default,k8s:io.cilium.k8s.policy.serviceaccount=minio-operator,k8s:io.kubernetes.pod.namespace=minio,k8s:operator=leader |
| process/pod/container/id | string | docker://97b5d10913ddc80e4409e715f0c73e2d77a57d133a88baa6330a3d488202ec45 |
| process/pod/container/name | string | operator |
| process/pod/container/start_time | 1675087549000 | |
| process/pod/container/pid | number | 1 |
| process/pod/container/maybe_exec_probe | boolean | false |
| process/pod/container/image/id | string | docker-pullable://minio/operator@sha256:5f5f31cf46a7683dc37aeaf598baf552640c03ac6fc8f2aac169e015d077e935 |
| process/pod/container/image/name | string | minio/operator:v4.5.1 |
| parent/exec_id | string | bWluaWt1YmU6MjA2NjMwMDAwMDAwOjIzMTMy |
| parent/pid | number | 23132 |
| parent/uid | number | 23132 |
| parent/cwd | string | /run/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/97b5d10913ddc80e4409e715f0c73e2d77a57d133a88baa6330a3d488202ec45 |
| parent/binary | string | /usr/bin/containerd-shim |
| parent/arguments | string | -namespace moby -workdir /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/97b5d10913ddc80e4409e715f0c73e2d77a57d133a88baa6330a3d488202ec45 -address /var/run/docker/containerd/containerd.sock -containerd-binary /usr/bin/containerd -runtime-root /var/run/docker/runtime-runc -systemd-cgroup |
| parent/flags | string | procFS auid |
| parent/start_time | number | 1675087548962 |
| parent/auid | number | 0 |
| parent/docker | string | |
| parent/parent_exec_id | string | bWluaWt1YmU6MTI0OTYwMDAwMDAwOjE3NDc1 |
| parent/refcnt | number | 0 |
PROCESS_CONNECT
| time | number | 1674748552434 |
| kind | string | PROCESS_CONNECT |
| id | string | minikube/1674748552.434000000/PROCESS_CONNECT/bWluaWt1YmU6MTMxMzQwMDAwMDAwOjIwMzA5 |
| process/exec_id | string | bWluaWt1YmU6MTMxMzQwMDAwMDAwOjIwMzA5 |
| process/pid | number | 20309 |
| process/uid | number | 20309 |
| process/start_time | 1674748552434 | |
| process/docker | string | da15ebaf7183a00c0a5e949ad535167 |
| process/parent_exec_id | string | bWluaWt1YmU6MTMxMzIwMDAwMDAwOjIwMjky |
| process/pod/labels | string | |
| process/pod/container/id | string | docker://da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc |
| process/pod/container/start_time | string | 1674748552000 |
| process/pod/container/maybe_exec_probe | string | |
| process/pod/namespace | string? | minio |
| process/pod/name | string? | minio-operator-5f4cb79d7c-6rzr6 |
| process/pod/labels | string? | |
| process/pod/container/id | string? | docker://da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc |
| process/pod/container/name | string? | operator |
| process/pod/container/start_time | string? | 1674748552000 |
| process/pod/container/pid | number? | 1 |
| process/pod/container/maybe_exec_probe | boolean? | false |
| process/pod/container/image/id | string? | docker-pullable://minio/operator@sha256:5f5f31cf46a7683dc37aeaf598baf552640c03ac6fc8f2aac169e015d077e935 |
| process/pod/container/image/name | string? | minio/operator:v4.5.1 |
| parent/exec_id | string | bWluaWt1YmU6MTMxMzIwMDAwMDAwOjIwMjky |
| parent/pid | number | 20292 |
| parent/uid | number | 20292 |
| parent/cwd | string | /run/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc |
| parent/arguments | string | -namespace moby -workdir /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/da15ebaf7183a00c0a5e949ad5351671936c9a765b0d1a3ef27eed1cfa6e49fc -address /var/run/docker/containerd/containerd.sock -containerd-binary /usr/bin/containerd -runtime-root /var/run/docker/runtime-runc -systemd-cgroup |
| parent/start_time | 1674748552414 | |
| parent/parent_exec_id | string | bWluaWt1YmU6OTcyOTAwMDAwMDA6MTIyNTc= |
| source_ip | string | 10.88.0.38 |
| source_port | number | 55142 |
| destination_ip | string | 10.96.0.1 |
| destination_port | string | 443 |
| destination_names | string | |
| sock_cookie | number | 0 |
| protocol | number | 6 |
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Hubble Process Ancestry on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
Marketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Get this plugin
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install Hubble Process Ancestry from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.3
- Added missed dark theme icons
1.0.2
- Update Process Ancestry component (@isovalent/grafana-process-tree v0.3.0) with performance improvements and fixes
- Make Process Ancestry scrollable
- Upgrade dependencies
- Migrate from Yarn to NPM
1.0.1
- Add LICENSE and COPYRIGHT.
- Update README.md
- Update the logo
1.0.0
Initial release.
