Synthetic monitoring application
Synthetic Monitoring is a blackbox monitoring solution provided as part of Grafana Cloud. Synthetic Monitoring provides users with insights into how their applications and services are behaving from an external point of view. Users can define checks to continually test remote targets from 1 or more probe locations around the world to assess the availability, performance and correctness of the services. As each check runs, metrics and logs are collected and published to the user's Grafana Cloud service. Metrics are published to Grafana Cloud Prometheus and logs are published to Grafana Cloud Loki.
Synthetic monitoring is the successor to the original worldping application. The refreshed Synthetic Monitoring product focuses on reducing complexity and taking advantage of Grafana Cloud capabilities.
Check Types
Users can define HTTP/HTTPS, DNS, TCP and ICMP Ping checks to monitor their remote targets. Internally, the Synthetic Monitoring solution uses the Prometheus Blackbox exporter for executing the checks and collecting metrics and logs. When creating a check, users are able to customize the settings and validation rules supported by the Blackbox exporter.
Probe Locations
For each check, users can select 1 or more 'public' probe locations distributed throughout the world to run tests from. Additionally, users can run their own 'private' probe locations by downloading and deploying the Synthetic Monitoring Agent.
Configuration
Refer to the CONTRIBUTING.md guide for instructions on how to set up the Synthetic Monitoring app and run it locally.
- ...and more
Insights
- Adoption
Running on 58,989 active Grafana instances.
- Activity
Last updated 9 Oct 2026.
38 releases in the past year.
- Version
- 1.65.0
- Dependencies
- Grafana >=13.2.0-0
- Developer
- Grafana Labs
- ...and more
