Plugins
Data sourceGrafana
PostgreSQL logo
PostgreSQL
Grafana Labs
Get plugin
Grafana PostgreSQL Data Source - Native Plugin
Grafana ships with a built-in PostgreSQL data source plugin that allows you to query and visualize data from a PostgreSQL compatible database.
Adding the data source
  1. Open the side menu by clicking the Grafana icon in the top header.
  2. In the side menu under the Dashboards link you should find a link named Data Sources.
  3. Click the + Add data source button in the top header.
  4. Select PostgreSQL from the Type dropdown.
http://docs.grafana.org/features/datasources/postgres/
Insights
  • Adoption
    Running on 899,312 active Grafana instances.
  • Activity
    Last updated 28 Oct 2026.
    7 releases in the past year.
  • Queries
    1,608,263,584 total queries served across all Grafana Cloud instances.
Version
13.0.6
Dependencies
  • Grafana >=12.3.0-0
Developer
Grafana Labs
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
