Sensor Floor Map
Draws a floor plan from SVG and colours each room by its live sensor readings (temperature, humidity, CO₂ or any other metric), judged against each sensor's own limits.
Features
- Built-in floor plan editor. Draw rooms, generate one per sensor location from the query, or let the AI assistant draw or trace a plan from a description, an image or a PDF.
- Any floor plan. You can also paste SVG: tag room shapes with
data-room="Name", or give them an id ofroom-Name. The markup is sanitised before it is shown. - Any data source. Reads tables (one row per reading, with a sensor column) and labelled series such as InfluxDB/Flux results. Field names are detected automatically or can be set by hand.
- Status at a glance. Each room is within limits, near a limit, out of limits, offline (no recent reading) or without a sensor. Rooms can also be coloured by where the temperature or humidity sits inside its band.
- Any metric. Every numeric field is a metric. Units, decimals and limits come from Grafana's field config and overrides, or from the data per sensor. Temperature, humidity, CO₂, PM2.5 and PM10 have sensible defaults.
- Sensor binding by name, or by picking a sensor for each room in the options pane.
- Hover for the full reading. Click a room to open a URL that can use dashboard variables plus
${room},${sensor}and${location}.
Getting started
- Add the panel. It shows a small demo office plan until you draw your own with Plan drawing → Edit floor plan.
- Query your sensor data. The newest reading of each sensor is used.
- Rooms whose name matches a sensor's location or id are bound automatically. Bind the rest under Rooms → Sensor per room.
Full documentation: https://github.com/dkhoa-dev/grafana-sensor-floor-map#readme
- ...and more
Insights
- Adoption
Running on 6 active Grafana instances.
- Activity
Last updated 3 Nov 2026.
1 release in the past year.
- Version
- 0.2.2
- Dependencies
- Grafana >=13.2.0
- Developer
- dkhoa
- ...and more
