Plugins
ApplicationCommercial
Azure Cloud Native Monitoring logo
azure
Get plugin
Azure Cloud Native Monitoring Static Badge
Overview
Homepage
This Grafana App Plugin provides a seamless and enhanced monitoring experience for Azure Kubernetes Service (AKS) users. It integrates Azure, AKS, and Prometheus to offer a comprehensive view of your AKS environment.
Simplified User Experience: Users can access fully populated charts and experiences by selecting the cluster of interest. The plugin reduces the number of user inputs required, automatically discovering and populating variables such as Prometheus datasource and Log Analytics workspace.
Granular Monitoring: It displays monitoring data at various levels of granularity, from multi-cluster to individual containers, allowing users to drill down into specific areas of interest.
Curated Azure Monitoring: The plugin provides a curated Azure monitoring experience within Grafana, making it available in the public Grafana catalog and compatible with various Grafana platforms.
Enhanced Troubleshooting: It improves the AKS troubleshooting experience by providing better navigation, a range of supported visualizations, and keeping users in the same context.
Requirements
This plugin works with Azure Monitor Datasource and Prometheus datasource configured with the Azure Monitor managed service for Prometheus. Please make sure you have configured in your instance:
Permissions requirements
Regardless of the Azure Authentication method you are using, the following are the minimum required permissions that you Grafana instance needs for the resource you are trying to query data from:
  • Azure Monitor: Monitoring Reader
  • Azure Managed Prometheus: Monitoring Data Reader
Getting started
If this plugin has not yet been enabled on your Grafana instance, Click on Install then Enable. This will automatically add an entry point on your Grafana navigation bar under Apps
Grafana Navigation Bar
Simply click on it and start your troubleshooting journey!
If you are self hosting your Grafana instance and would like to see the plugin as a root item in your navidation menu, you need to add the following config in your grafana.ini file.
[navigation.app_sections]
azure-monitor-app = "root"
Contributing
Please go to our repo to learn more about how to contribute
If you would like to report an issue or provide feedback, please open a github issue
Insights
  • Adoption
    Running on 1,469 active Grafana instances.
  • Activity
    Last updated 6 Feb 2025.
    0 releases in the past year.
Version
0.0.3
Dependencies
  • Grafana >=10.4.0
Developer
azure
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
