Now GA: Cortex blocks storage for running Prometheus at scale with reduced operational complexity
2020-10-072 min
We’ve just launched Cortex 1.4.0, one of the most significant releases of 2020. The big headline: The new blocks storage engine has exited the experimental phase and is now marked as Generally Available.
Blocks storage aims to reduce the operational complexity and costs of running a Cortex cluster at scale. In particular, it removes the dependency from a NoSQL database to store series indexes, and only leverages object storage (e.g., S3, GCS, or Azure blob storage) to store all the ingested series, without compromising reliability, scalability, or performance. Removing this dependency should significantly reduce the cost to run Cortex, as NoSQL databases tend to be quite expensive to run compared to object storage – whether you are paying a cloud provider to run it for you, or running on premise.
In blocks storage mode, the Cortex architecture looks like this:
Embedded image
If you’re familiar with Cortex, you’ll notice that the general architecture remains unchanged, with only the addition of two services: store-gateway and compactor.
After successfully running blocks storage in production for three months, Grafana Labs is currently completing the migration of all production clusters from chunks to blocks storage. You can read more about our experience with blocks storage at Grafana Labs in this blog.
Other notable developments in Cortex 1.4.0 include:
  • Cassandra marked as GA.
  • Support for Redis sentinel and Redis cluster to the Redis caching backend introduced.
  • Major improvements to ruler and alertmanager.
  • Shuffle-sharding support introduced to store-gateways blocks sharding. This allows tenant blocks to be spread across a subset of store-gateway instances, which limits the potential impact that can be introduced by any single tenant’s workload. A lot more about shuffle-sharding will come in the next release.
For more details, please read the Cortex 1.4.0 release notes.
Finally, our recently released commercial offering Grafana Metrics Enterprise, which adds some great enterprise-specific features on top of Cortex, will of course include all of these new changes in a future release, as it brings along with it the full upstream Cortex.
