Plugins 〉AJAX
The AJAX plugin has been deprecated and is no longer maintained.
AJAX
AJAX Panel for Grafana
The AJAX Panel is a general way to load external content into a grafana dashboard.
Options
Method:
GET or POST or iframe
URL:
The URL to request
Parameters:
The parameters that will be passed in the request. This is a javascript object with access to the variables: -
ctrlThe control object.
Screenshots
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing AJAX on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install AJAX from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Change Log
All notable changes to this project will be documented in this file.
v0.1.0
- Comipled and with grafana 7+,
- image support requires 7.4+
v0.0.7
- building with @grafana/toolkit
- Tested with Grafana 6.3
- fix height issue with iframes
v0.0.6
- Support requests to /api (grafana internal API)
- Adding circleci build
- removing dist from master build (only add it on release branches)
- Support empty text response (#9)
- webpack build
- Show query results
- tested with grafana 6
v0.0.5
- Support angular templates using AJAX response
- Options to display as: HTML, Text, JSON, or preformatted text
- Fixed display issue with 5.1
- Support direct link rendered image
- Show possible variables in editor
v0.0.4
- Support template variables in parameters (@linar-jether)
- Improved error handling
- Move ajax requests to 'issueQueries' block rather than refresh
- Show loading spinner
- Convert to TypeScript
- Use datasources for complex authentication
- Support loading images
- Support header configuration
- Support showing time info
- Include various sample configurations
v0.0.3
- Support template variables in url (@linar-jether)
- Adding iframe method (@linar-jether)
v0.0.2
- Quick and Dirty, but it works!
