Plugins
FlightSQL logo
FlightSQL
InfluxData, Inc.
Get plugin
FlightSQL
Grafana FlightSQL Data Source - Community Plugin Install a FlightSQL data source plugin that allows you to query and visualize data using SQL enabling queries to FlightSQL APIs.
Adding the data source Open the side menu by clicking the Grafana icon in the top header. In the side menu under the Dashboards link you should find a link named Data Sources. Click the + Add data source button in the top header. Select FlightSQL from the Type dropdown.
Find out more here:
Github
Arrow
Docs
Version
1.1.1
Dependencies
  • Grafana >=9.2.5
Developer
InfluxData, Inc.
Last Updated
January 13, 2025
