SurrealDB data source plugin
[!IMPORTANT] Deprecation Notice: This plugin is deprecated and will only receive critical security updates. Support will end on June 1, 2026.
The SurrealDB datasource plugin enables you to query and visualize SurrealDB data directly within Grafana, offering seamless integration and exploration of SurrealDB datasets.
⚠️ SurrealDB v2.0 compatibility
Important: The Grafana SurrealDB datasource currently does not support SurrealDB v2.0. Please ensure you are using a compatible version of SurrealDB (v1.x) for full functionality. Follow the GitHub issue here for updates on compatibility.
What are Grafana data source plugins?
Grafana supports a wide range of data sources, including Prometheus, MySQL, and even Datadog. There’s a good chance you can already visualize metrics from the systems you have set up. In some cases, though, you already have an in-house metrics solution that you’d like to add to your Grafana dashboards. Grafana Data Source Plugins enables integrating such solutions with Grafana.
Usage
Installation
Please refer to our Data Source Management documentation for more information on installing the plugin to an instance of Grafana.
Configuration
Add a data source by filling in the following fields:
Basic fields
| Field | Description |
| Endpoint URL | The full address of the SurrealDB RPC endpoint to connect to, e.g. ws://localhost:8000/rpc |
| Database name | The name of the database to connect to. |
| Namespace | The namespace to use for the connection. |
Authentication fields
| Username | Your SurrealDB username |
| Password | Your SurrealDB password |
| Scope | The scope to use for the user. (Optional) |
We strongly recommend that you make your queries with a user account that has read-only access. This practice not only safeguards your data but also helps maintain system integrity.
Querying
The query editor allows you to write SurrealQL queries. For more information about writing SurrealQL queries, please refer to SurrealDB's documentation.
In this version, only a SurrealQL Editor is provided to write queries with. A Query Builder UI is planned for a later version of the plugin.
Development
This project requires at least Node.js v20 and at least Go 1.21.
Version management configuration for Node.js is provided for volta. It is recommended that you have this installed to automatically switch between Node.js versions when you enter the project directory. This allows for more deterministic and reproducible builds, which makes debugging easier.
You use volta to configure the project to use the latest LTS version of Node.js by running:
volta pin node@lts
You can run this command again to update the version.
Getting started
Backend
Update Grafana plugin SDK for Go dependency to the latest minor version:
go get -u github.com/grafana/grafana-plugin-sdk-go go mod tidyBuild backend plugin binaries for Linux, Windows and Darwin:
mage -vList all available Mage targets for additional commands:
mage -l
Frontend
Install dependencies
npm installBuild plugin in development mode and run in watch mode
npm run devBuild plugin in production mode
npm run buildRun the tests (using Jest)
# Runs the tests and watches for changes, requires git init first npm run test # Exits after running all the tests npm run test:ciSpin up a Grafana instance and run the plugin inside it (using Docker)
npm run serverRun the E2E tests (using Cypress)
# Spins up a Grafana instance first that we tests against npm run server # Starts the tests npm run e2eRun the linter
npm run lint # or npm run lint:fix
- ...and more
Insights
- Adoption
Running on 229 active Grafana instances.
- Activity
Last updated 17 Jun 2026.
2 releases in the past year.
- Queries
12,225 total queries served across all Grafana Cloud instances.
- Version
- 0.2.9
- Dependencies
- Grafana >=9.5.3
- Developer
- Grafana Labs
- ...and more
