Plugins
Singlestat logo
Singlestat
Grafana Labs
Get plugin
This plugin has been deprecated and is no longer maintained.
Singlestat
The Singlestat panel allows you to show the one main summary stat of a single time series.
Note: Singlestat has been superseded by the Stat panel and is no longer available from Grafana 8.0. For more information on how to migrate, refer to Migrate to the new Stat panel.
Features
  • Reduce a time series into a single numeric value
  • Configure thresholds to color the stat or the panel background
  • Translate the numeric value into a text value
  • Show a sparkline summary of the time series
Installation
To install using the Grafana CLI, run the following command in the terminal:
grafana-cli plugins install grafana-singlestat-panel
For more ways to install the plugin, refer to Install Grafana plugins.
Documentation
For more information on how to use the Singlestat panel, refer to Singlestat Panel .
Starting with Grafana 8.0, panels using the Singlestat visualization will be automatically migrated to the new Stat panel.
If you don't want to switch to the Stat panel just yet, you can prevent the migration by installing this plugin before you start Grafana.
Version
2.0.0
Dependencies
  • Grafana >=8.0.0
Developer
Grafana Labs
Last Updated
May 16, 2023
