Jenkins data source
Note: The Jenkins data source is currently in public preview. We would welcome your feedback on this plugin to help shape its future.
Jenkins is an open source automation server used to build and deploy projects as part of Continuous Integration (CI) and Continuous Deployment (CD) pipelines.
The Jenkins data source plugin allows you to query and visualize metrics such as projects, builds, build queues, nodes and load statistics from within Grafana. This information can be used to measure performance against DORA metrics to assess your software delivery and operations performance.
Requirements
This plugin has the following requirements:
- A Jenkins instance with Remote Access API enabled.
- Access to Enterprise plugins. Note: these plugins are also available in the Free tier of Grafana Cloud. For more information, see our Pricing.
Documentation
For detailed guidance on installation, configuration and usage, refer to our Documentation
Bug reports, feature requests and feedback
The Jenkins data source is supported by Grafana Labs, if you encounter an issue or would like to raise a feature request - please contact support.
Alternatively, issues may also be created in the Grafana GitHub repository.
- ...and more
Insights
- Adoption
Running on 262 active Grafana instances.
- Activity
Last updated 5 Feb 2026.
1 release in the past year.
- Queries
456 total queries served across all Grafana Cloud instances.
- Version
- 1.1.0-preview
- Dependencies
- Grafana >=10.4.8
- Developer
- Grafana Labs
- ...and more
