This plugin has been deprecated and is no longer maintained.
Guided tour panel for grafana dashboards
Add guided tour to your Grafana dashboards.
Disclaimer: This plugin is an EXPERIMENTAL plugin. Only tested against selected versions of grafana and specific use cases.
Features
- Add guided steps targeting dashboard panels
- Customize the tour controller with custom markdown
- Customize tour color theme and style
- Support for grafana dark and light mode
- Does support markdown content
- Option to auto start the tour on dashboard load
- Option to redirect to different dashboard at the end of the tour
Setup
- Add Guided Tour Panel to your dashboard like any other panel.
- Add as many steps required. Provide exact panel title for the step and then specify content. Content can be in markdown format.
- Customize the look and feel if required.
Known limitations
- Panels you are navigating should be in viewport
- Panels collapsed inside dashboard rows can't be targeted
- Guided tour panel controller needs to be at the top of the dashboard or at least it should be in viewport
- Version
- 0.2.0
- Dependencies
- Grafana >=8.1.0
- Developer
- Grafana Labs
- Last Updated
- May 20, 2026
