Plugins
Data sourceGrafanaEnterprise
Amazon Aurora logo
Amazon Aurora
Grafana Labs
Get plugin
Amazon Aurora data source for Grafana
The Amazon Aurora data source lets you query and visualize data from your Amazon Aurora clusters in Grafana. The plugin supports both PostgreSQL-compatible and MySQL-compatible Aurora engines, and connects to your cluster using AWS IAM database authentication, so you don't store database passwords in Grafana.
This data source is currently in public preview.
Note: The Amazon Aurora data source is an Enterprise plugin. It's available with a Grafana Cloud Pro or Advanced plan and Grafana Enterprise.
Features
  • Query Aurora PostgreSQL-compatible and MySQL-compatible engines with a full SQL editor.
  • Authenticate with AWS IAM database authentication using access keys, a credentials file, or the AWS SDK default provider, with optional role assumption.
  • Format results as table or time series data, with support for time filter macros such as $__timeFilter.
  • Use query results to populate dashboard template variables.
  • Create Grafana Alerting rules based on Aurora queries.
  • Connect to private clusters with private data source connect (PDC) on Grafana Cloud.
  • Provision data sources with YAML or Terraform.
Requirements
  • Grafana 9.4.0 or later. Private data source connect requires Grafana 10.0 or later.
  • An Amazon Aurora cluster with IAM database authentication enabled.
  • A database user configured for IAM authentication, and AWS credentials with the rds-db:connect permission.
Documentation
For full documentation, refer to the Amazon Aurora data source documentation:
Get help
Insights
  • Queries
    27,732 total queries served across all Grafana Cloud instances.
