Plugins 〉Statusmap
The Statusmap plugin has been deprecated and is no longer maintained.
Statusmap
Statusmap panel for Grafana
Panel to show discrete statuses of multiple targets over time.
Run
docker compose upand open http://localhost:3000 in browser to see a simple demo.
Features
- Grouping values into rows and buckets using legend from query
- User defined color mapping
- Multiple values in bucket are displayed via tooltip
- Configurable tooltip items
- Pagination for rows
- Increasing rows/buckets' interval for better visual representation
- Representing null values as empty bucket or zero value
Supported environment
- Tested with:
- Prometheus
- InfluxDB
- Mysql
- Grafana 7.x, 8.x
- Support for earlier Grafana versions:
- 0.5.x versions should work in Grafana 6.5.x - 6.7.x with timeseries data format
- (0.4.2)[https://github.com/flant/grafana-statusmap/releases/tag/v0.4.2] should work in Grafana 5.4.x - 6.4.x
Motivation
We had a desperate need to visualize a set of timeseries statuses over time period, so we can see a history of changes for objects' status. Since we maintain a lot of Kubernetes clusters (and related infrastructure), our main cases for that are visualization of servers & Kubernetes pods health states as well as HTTP services health checks. We've tried a variety of Grafana plugins available (they are listed in Acknowledgements below) but none of them could provide the features and visualization really close to what we've been looking for.
NB: You can find more details about our journey of creating the plugin in this post.
Objects being visualized with this plugin may be different: not only IT components (e.g. server
hosts and Kubernetes pods) but just anything you can imagine like coffee makers on the picture
above. These objects should have discrete statuses which are sets of predefined values, e.g.
ok = 0, off = 1, fail = 2, etc.
Configuration
Datasource notes
To create neat graphs your datasource should return good data. Plugin adjust $__interval variable depending on
bucket width in panel options. Your queries should aggregate statuses over $__interval.
To make multiple values mode works as expected you should define multiple queries: one query for each possible status.
Plugin doesn't aggregate data in time for now, it only renders input data as buckets. Because of this data should contain points for each timestamp in time range and equal timestamps for every possible target (y-axis label). This limitation is addressed by issue #53.
Prometheus
To work with data from Prometheus you will need to setup discrete statuses for your objects. Requirements to store these statuses in metrics are as follows:
- metrics should have two values:
0and1; - there should be a label with status' value.
When it's done, you can collect all the data via query, e.g.:
(max_over_time(coffee_maker_status{status="<STATUS_VALUE>"}[$__interval]) == 1) * <STATUS_VALUE>
If there was no such status (<STATUS_VALUE>) during query's interval, Prometheus would
return nothing. Otherwise, status' value will be returned.
For example, if you have 5 types of statuses and a metric (coffee_maker_status) with 5
allowed values (0, 1, 2, 3, 4), you should transform this metric using following rule:
- record: coffee_maker_status:discrete
expr: |
count_values("status", coffee_maker_status)
That's how coffee_maker_status metric with value 3 will be transformed into new metric:
coffee_maker_status:discrete{status="3"} 1
Now, when Prometheus has 0 and 1 values for each status, all these metrics can be
aggregated, so you will get all available statuses of your objects over time.
InfluxDB
Choose 'Time series' for 'Format as' and use GROUP BY ($__interval) in query. $tag_<tag name> can be used in 'Alias by' to define y-axis labels.
Mysql
Example query with aggregation over $__interval is like this (you need one query for each possible status value):
SELECT
$__timeGroupAlias(date_insert,$__interval),
name AS metric,
min(statusi) AS "statusi"
FROM coffee_makers
WHERE
$__timeFilter(date_insert) AND statusi=1
GROUP BY 1,2
ORDER BY $__timeGroup(date_insert,$__interval)
metric column is used as y-axis label.
Panel
First of all, an individual query for each possible status' value should be created. Each query should also have similar legend for grouping:
Then, color mapping for status' values should be defined in Discrete color mode:
Use can use presets to define a trafic light colors or 8 colors from solarized palette:
Note: Spectrum and Opacity color modes function the same way they do in Heatmap plugin.
More options
Bucket
Multiple values checkbox specifies how they should be displayed:
- If it's off, multiple values for one bucket are treated as error;
- If it's on, color for such bucket would be determined by the value having least index in color mapping.
Display nulls can be treated as empty buckets or displayed with the color of 0 value.
Min width and spacing are used to specify minimal bucket width and spacing between buckets. Rounding may be used to round edges.
Values index set to positive number to display only values from specified timeseries.
Display
Show legend checkbox toggles legend at the bottom of the panel.
Rows sort can be used to sort labels on Y axis. Metrics — sort y labels as they are defined on Metrics tab. a→z and z→a sort labels descending or ascending in a natural order.
Pagination
Enable pagination toggles pagination controls on graph.
Rows per page a number of rows to display on graph.
Tooltip
Show tooltip toggles tooltip display on mouse over buckets.
Freeze on click toggles tooltip "freezing" on click. Frozen tooltip can be used to compare data with floating tooltip or to follow URLs.
Show items toggles display of additional items in tooltip.
Items is a list of definitions to display URLs in tooltip.
Each URL has a template, icon, label and formating options: lowercase and date format for variables.
Percentual bucket spans
In some cases scenarios, the status panel is used to go from one dashboard to a more specific one, e.g. when performing root/cause analysis. In such cases, the user may want to reduce the scope of the time span, while keeping the desired event centered (to be able to analyse the previous/posterior buckets of time). Those values are introduced through __bucket_from and __bucket_to.
__bucket_from: It's the value of bucket.from minus the percentual bucket.
__bucket_to: It's the value of bucket.to plus the percentual bucket.
- Changelog
- Use GitHub Discussions to ask for help.
- Installation
- Setup development environment to help us improve the plugin.
Acknowledgements
The first public release of this plugin has been fully made by Flant engineers. The whole idea has come from Dmitry Stolyarov (@distol), initial version has been written by Sergey Gnuskov (@gsmetal) and final changes has been made by Ivan Mikheykin (@diafour).
This plugin is based on "Heatmap" panel by Grafana and partly inspired by ideas from Carpet plot, Discrete panel, Status Panel, Status Dot, Status By Group.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Statusmap on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
Marketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Get this plugin
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install Statusmap from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
v0.5.1
- Fix fallback to timeseries for Grafana 6.x
- Change docker-compose.yaml to work with Grafana 6.x
v0.5.0
- Support DataFrames. (#239)
- Add tooltip variables with percentual bucket range: __bucket_from, __bucket_to (#242)
- Support Grafana 8.4+
- Hide markers in tooltip.
v0.4.2
- Compatibility with Grafana 8.1+. (#230, #219, #220, #221)
- Fix 'as zero' for spectrum mode. (#208, #209)
v0.4.1
- Fix regression in discrete mode. "Data has value with undefined color"
v0.4.0
- Add __y_label_trim variable for tooltip items.
- Add y-label splitter for tooltip items.
- Add custom content for tooltip.
- Fix to work with Grafana 7.4.x.
- Migrate to grafana-toolkit and yarn to build and sign.
- Cleanup dist directory content, reduce compiled plugin size, remove dist from repository.
- Code cleanup: fix huge amount of linter errors and warnings.
- Add Github Actions configuration to automate release process.
- Add unobtrusive branding.
v0.3.4
- Fix to work in Grafana 7.2.0,7.2.1
- Fix 'name' in tooltip for opacity and gradient modes
- Fix color scale for opacity and gradient modes
v0.3.3
- Fix fallback to string events for older versions of Grafana
v0.3.2
- Fix plugin metadata for Grafana repository
v0.3.1
- Fix to work in Grafana 7.1.0
v0.3.0
- Tooltip freeze on click
- Show URLs in tooltip
- Pagination controls
- Fix tooltip and null buckets
- Fix display for 6.7+, 7.0+
v0.2.0
- Migrate code base to typescript
- Fixes to work in 6.3.0+ grafana
v0.1.1
- Fix for annotations in grafana 5.x before 5.4
v0.1.0
- Tested with Grafana 6.0.0
- Tested with InfluxDB and Mysql datasources
- Add initial support for display annotations
- Add example for k8s statuses (thanks, @vrutkovs)
- Fix hanging on big values
- Fix horizontal spacing = 0
- Fix for "Object doesn't support property or method 'remove'"
- Fix card width for targets with different datapoints count
v0.0.4
- Fix display of multivalues buckets as an empty cell
v0.0.3
- Add solarized preset
- Reorganize statuses editor for discrete mode
- Separate options for vertical and horizontal spacing for cards
- Add simple sort options for Y axis
- Fix display null values as zero
v0.0.2
- Install with GF_INSTALL_PLUGINS
- Fix legend overlap
- Fix colors for dark theme
- Fix panel rendering timeout error
v0.0.1
- First public release
