Plugins
PanelCommunity
Breadcrumb logo
Breadcrumb
digiapulssi
Get plugin
This plugin has been deprecated and is no longer maintained.
Breadcrumb Panel Plugin for Grafana
This is a panel plugin for Grafana. It keeps track of dashboards you have visited within one session and displays them as a breadcrumb. Each dashboard is added only once to the breadcrumb. You can navigate back to some dashboard in breadcrumb by clicking the dashboard name link text. When navigation back all items coming after the selected dashboard will be removed from the breadcrumb. Note that breadcrumb can track only dashboards that have breadcrumb panel on them.
To understand what is a plugin, read the Grafana's documentation about plugins.
Options
Is root dashboard - Panel has an option for setting it as the root. If set, this will clear breadcrumb in root dashboard. Hide text in root dashboard - Don't show anything if breadcrumb has only one item Limit the amount of breadcrumb items to - The amount of breadcrumb items is limited by default. The oldest item is removed when exceeded.
Features
Compiling
npm install
grunt
The compiled product is in dist folder.
Deployment
Copy the contents of dist folder to plugins/breadcrumb folder so Grafana will find the plugin and it can be used in Grafana dashboards.
Install the Panel
Use the grafana-cli tool to install Breadcrumb from the commandline:
grafana-cli plugins install digiapulssi-breadcrumb-panel
The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins.
Insights
  • Adoption
    Running on 11,656 active Grafana instances.
  • Activity
    Last updated 2 Sep 2022.
    0 releases in the past year.
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
