How Prometheus Remote Write v2 can help cut network egress costs by as much as 50%
Back in 2021, Grafana Labs CTO Tom Wilkie (then VP of Products) spoke at PromCON about the need for improvements in Prometheus' remote write capabilities.
“We use between 10 and 2 bytes per sample to send via remote write, and Prometheus only uses 1 or 2 bytes per sample on the local disk so there’s big, big room for improvement,” Wilkie said at the time. “A lot of the work we’re going to do on atomicity and batching will allow us to have a symbol table in the remote write requests that will reduce bandwidth usage.”
Nearly five years later, we're pleased to see the work to improve those bandwidth constraints is paying off. Prometheus Remote Write v2 was proposed in 2024, and even in its current experimental status, we're already seeing adoption in Prometheus backends and telemetry collectors reaping benefits (i.e., significant cost savings!) that are worth noticing.
In this blog, we'll explain the benefits of this v2 and show how to enable it in Alloy. We'll also give you a sense for the massive improvements we've seen in our egress costs and how you can unlock similar cost savings for your organization.
What is remote write, and what’s great about v2?
When you want to send your metrics to a Prometheus backend you use Prometheus Remote Write. The remote write v1 protocol does a great job of sending metric samples, but it was designed in a time before metric metadata (metric type, unit, and help text) was as necessary as it is today. At the same time, it’s also not the most efficient wire protocol—sending lots of duplicate text with each sample adds up and creates really large payloads.
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="0"}
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="5"}
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="10"}
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="25"}
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="50"}
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="10000"}
request_size_bytes_bucket{method="POST",response_code="200",server_address="otlp.example.com",le="+Inf"}
request_size_bytes_sum{method="POST",response_code="200",server_address="otlp.example.com"}
Remote write v2 adds first-class support for metadata in the sample payload. But the real efficiency and cost savings come from the symbol table implementation referenced in Wilkie's 2021 talk.
symbols: ["request_size_bytes_bucket", "method", "POST", "response_code", "200", "server_address", "otlp.example.com", "le", "0", "5", "10", "25", "50", ... "10000", "+Inf", "request_size_bytes_sum"]
0{1=2,3=4,5=6,7=8}
0{1=2,3=4,5=6,7=9}
0{1=2,3=4,5=6,7=10}
0{1=2,3=4,5=6,7=11}
0{1=2,3=4,5=6,7=12}
0{1=2,3=4,5=6,7=13}
0{1=2,3=4,5=6,7=14}
15{1=2,3=4,5=6}
The more repeated strings you have in your samples from metric names, label names, label values, and metadata, the more efficiency gains you get compared to the original remote write format.
Why did this matter for Grafana?
Running Grafana Cloud generates a lot of telemetry! We monitor millions of active series at between one and four DPM, and that telemetry adds up to a large amount of network egress.
That's why we migrated all of our internal Prometheus monitoring workloads at Grafana Labs from remote write v1 to remote write v2 last fall. With a very minor 5% to 10% increase in CPU and memory utilization, this simple change reduced our network egress costs for our internal telemetry by more than 50%. At the rates large cloud providers charge, this was a negligible added resource cost for a very large savings in network costs.
Note: If you experience a different reduction in traffic when you implement v2, you can experiment with the batching configuration in your prometheus.remote_write component—larger batches will likely display higher traffic reduction.
Why should this matter to you?
Observability costs can add up quickly, and teams often struggle to decide which telemetry is essential and which they can do without. However, remote write v2 is one change that doesn’t require careful evaluation or tough conversations. Simply enable the new experimental feature and see immediate savings.
Note: If you're looking for more ways to get better value from your observability setup, Grafana Cloud has multiple features designed to help reduce and optimize your costs.
Enabling remote write v2 in Alloy
The current remote write v2 specification is experimental in upstream Prometheus, and thereby experimental in Alloy. While both upstream Prometheus and Mimir support the current specification, there is still potential for breaking changes before the final release of the specification. For that reason, if you’re looking to enable remote write v2 in Alloy you will need to configure Alloy to run with the --stability.level=experimental runtime flag.
Alloy
After adding the experimental runtime flag, update the configuration of your prometheus.remote_write component’s endpoint block adding the protobuf_message attribute to the value io.prometheus.write.v2.Request. For example:
prometheus.remote_write "grafana_cloud" {
endpoint {
protobuf_message = "io.prometheus.write.v2.Request"
url = "https://example-prod-us-east-0.grafana.net/api/prom/push"
basic_auth {
username = "stack_id"
password = sys.env("GCLOUD_RW_API_KEY")
And it’s just as easy in an Alloy Helm chart:
image:
registry: "docker.io"
repository: grafana/alloy
tag: latest
alloy:
configMap:
content: |-
prometheus.remote_write "metrics_service" {
endpoint {
basic_auth {
Kubernetes Monitoring Helm Chart
In the Kubernetes Monitoring Helm chart v3.8, which is coming soon, you’ll have two ways to configure your Prometheus destination to use remote write v2. You can use the same configuration as Alloy and configure the protobufMessage for a destination. Alternatively, you can use the shortcut of defining the remoteWriteProtocol for a destination and it will output the correct protobufMessage in the rendered configuration.
destinations:
- name: grafana-cloud-metrics
type: prometheus
url: https://example-prod-us-east-0.grafana.net/api/prom/push
remoteWriteProtocol: 2
- name: grafana-cloud-metrics-again
type: prometheus
protobufMessage: io.prometheus.write.v2.Request
What’s next for Prometheus Remote Write?
We've been excited to see the gains that come with remote write v2, and we hope you can put them to use as well. However, there’s more improvements coming to remote write beyond the v2 specification, including:
- Improve resource utilization/reliability with Prometheus Agent and Alloy’s
prometheus.remote_writecomponent - Last but not least, some more resource utilization improvements for those using Alloy’s
prometheus.remote_writecomponent with Make labelstore.LabelStore in to a SeriesRefMappingStore · Issue #5062 · grafana/alloy
