Kubernetes observability: How to enrich logs with GeoIP using the Kubernetes Monitoring Helm Chart
When your Kubernetes app suddenly has traffic spikes in a distant country, it can be difficult to determine why. Let’s say, for example, we have an e-commerce app that started to receive an unusual surge of visitors from Australia — something we never anticipated. We search for answers in our logs, but without geographic context, we don’t have the full insights we need.
That’s when we can turn to GeoIP — the geolocation of IP addresses — to make sense of our logs and learn more about the end-user experience. Whether you’re troubleshooting issues, optimizing performance, or analyzing user trends, the ability to visualize log data with geographical context can provide valuable insights and help you to make data-driven decisions.
In this post, we’ll explore how you can use the Kubernetes Monitoring Helm Chart alongside MaxMind’s GeoIP database to enrich pod logs with geographic data based on IP addresses. We’ll cover how to set up the Helm Chart, configure log enrichment, and visualize that enriched log data in Grafana Cloud to gain deeper insights into your user base.
Why GeoIP enrichment matters
Kubernetes generates a wealth of log data that can play an important role in your overall observability strategy. These same logs, however, can provide even deeper insights when enriched with additional context. One form of enrichment is via geographical information, which can reveal where events are occurring and provide a deeper understanding of user interactions.
When troubleshooting or analyzing user behavior, knowing where your traffic originates can significantly improve your understanding and decision-making. GeoIP lookups enhance your logs by turning raw IP addresses into actionable geographical insights, helping you visualize traffic patterns and detect unusual activities.
Furthermore, GeoIP enrichment can aid in fraud detection by flagging suspicious activity from unusual locations and contribute to regulatory compliance by ensuring adherence to regional data privacy laws.
In summary, GeoIP enrichment enables you to:
- Quickly visualize user traffic geographically in Grafana.
- Detect unusual patterns or potential security threats based on location.
- Improve troubleshooting and reduce incident response time.
- Understand regional user behaviors, latency, and performance issues.
Prerequisites
Before we set up and integrate your Kubernetes cluster with Grafana Cloud for comprehensive observability and monitoring, you’ll want to make sure you have the following components in place:
- A Kubernetes cluster: This is the foundation of your containerized environment. You can either set up your own Kubernetes cluster using tools like kubeadm, minikube (for local development and testing), or kind, or leverage a managed Kubernetes service from a cloud provider, like Google Kubernetes Engine (GKE), Amazon Elastic Kubernetes Service (EKS), or Azure Kubernetes Service (AKS).
- Grafana Cloud: Grafana Cloud is a fully managed observability platform, providing a suite of tools for visualizing, monitoring, and alerting on your metrics, logs, and traces. If you don’t have a Grafana Cloud account, you can sign up for a free one today.
- Kubernetes Monitoring Helm Chart: This Helm Chart simplifies the deployment of Grafana Cloud Kubernetes Monitoring on your Kubernetes cluster. It makes it easy to start gathering telemetry data from your Kubernetes clusters and utilizes Grafana Alloy, our OpenTelemetry Collector distribution. It includes pre-configured dashboards and alerts specifically designed for monitoring Kubernetes environments. You’ll need to add the Kubernetes Monitoring Helm Chart repository to your Helm setup and then use Helm to install the chart.
- A MaxMind GeoIP license key: This license key is required if you want to leverage GeoIP lookups within your Grafana dashboards to visualize geographical data associated with your metrics. You can sign up for a MaxMind account and obtain a license key from their website.
Additional considerations include:
- kubectl: Ensure that you have the kubectl command-line tool installed and configured to interact with your Kubernetes cluster.
- Helm: Helm is a package manager for Kubernetes that simplifies the deployment and management of applications. Make sure you have Helm installed and set up.
- Network connectivity: Ensure that your Kubernetes cluster has the necessary network connectivity to communicate with Grafana Cloud and other external services, if required.
- RBAC (Role-Based Access Control): If your Kubernetes cluster has RBAC enabled, you might need to create appropriate roles and role bindings to grant Grafana Cloud the necessary permissions to access cluster resources.
Step 1: Deploy the Kubernetes Monitoring Helm Chart
Now that we’ve reviewed all project requirements, let’s get started by setting up the Kubernetes Monitoring Helm Chart. First, we want to add and update the Helm repository:
helm repo add grafana https://grafana.github.io/helm-charts &&
helm repo update
Then, deploy Grafana Cloud Kubernetes Monitoring with a complete observability stack (metrics, logs, traces, and profiling):
helm upgrade --install grafana-k8s-monitoring grafana/k8s-monitoring \
--namespace "default" --create-namespace \
--version "^2" --atomic --timeout 300s \
--values values.yaml
In your values.yaml, ensure you’ve enabled pod logs collection and Alloy logs:
podLogs:
enabled: true
Step 2: Integrate MaxMind GeoIP with pod logs
Next, we want to integrate with MaxMind’s GeoIP database so we can enrich our logs with geographic data.
To start, configure an init container to download the GeoIP database from MaxMind, and set up additional log processing stages to extract IP addresses from your logs and annotate them with geographic metadata.
Here’s an example configuration snippet from your values.yaml:
alloy-logs:
enabled: true
alloy:
stabilityLevel: public-preview
mounts:
extra:
- name: geoip
mountPath: /geoip
extraEnv:
- name: GCLOUD_RW_API_KEY
value: "<YOUR_GRAFANA_CLOUD_API_KEY>"
controller:
volumes:
extra:
- name: geoip
emptyDir: {}
initContainers:
- name: geoip-init
image: curlimages/curl:7.85.0
command: ['sh', '-c']
args:
for i in {1..5}; do
curl -o /geoip/GeoLite2-City.tar.gz -L "https://download.maxmind.com/app/geoip_download?edition_id=GeoLite2-City&license_key=<YOUR_MAXMIND_LICENSE_KEY>&suffix=tar.gz" && break || sleep 10;
done && \
tar -xzf /geoip/GeoLite2-City.tar.gz -C /geoip --strip-components=1 && \
rm /geoip/GeoLite2-City.tar.gz
volumeMounts:
- name: geoip
mountPath: /geoip
Note: Replace <YOUR_MAXMIND_LICENSE_KEY> with your actual MaxMind license key.
This configuration snippet enriches logs with geographic data by integrating MaxMind’s GeoIP database into your Kubernetes logging setup. Here’s a breakdown of what it does:
- Downloads the GeoIP database:
- It uses an init container to download the MaxMind GeoLite2 City database.
- The init container executes a
curlcommand to fetch the database file (GeoLite2-City.tar.gz) from the MaxMind download URL. - It then extracts the database file to the
/geoipdirectory within the container and removes the compressed archive.
- Configures log enrichment:
- The
alloy-logssection enables log processing using Alloy, which is deployed as part of the Kubernetes Monitoring Helm Chart. - It specifies mount points and environment variables for Alloy to access the GeoIP database and your Grafana Cloud API key (used for sending enriched logs to Grafana Cloud).
- The
volumessection defines a volume namedgeoipto store the GeoIP database.
- Handles download retries:
- The
forloop in thecurlcommand attempts to download the GeoIP database up to five times, with a 10-second sleep between attempts. This ensures robustness in case of temporary network issues.
Other key points to note:
- GeoIP enrichment: This configuration enables you to associate IP addresses in your logs with geographic information (country, city, continent) using the MaxMind database.
- Init container: The use of an init container ensures the GeoIP database is available before the main application starts processing logs.
- Values file: This configuration is typically part of a Helm chart’s
values.yamlfile, which allows you to customize the deployment by providing values for placeholders likeYOUR_MAXMIND_LICENSE_KEY. - Grafana Cloud integration: The configuration assumes you’re using Grafana Cloud for log visualization and analysis. The enriched logs will be sent to Grafana Cloud for further processing and visualization.
Step 3: Configure log processing for GeoIP enrichment
Next, update the podLogs.extraLogProcessingStages section to instruct Alloy to extract the IP address from logs, perform GeoIP lookups, and annotate logs accordingly:
podLogs:
enabled: true
extraLogProcessingStages: |-
stage.match {
selector = "{container=\"web-gateway\"}"
stage.logfmt {
mapping = { "ip" = "" }
stage.geoip {
source = "ip"
db = "/geoip/GeoLite2-City.mmdb"
db_type = "city"
stage.labels {
values = {
geoip_country_name = "",
geoip_country_code = "",
geoip_continent_name = "",
geoip_continent_code = "",
labelsToKeep:["app_kubernetes_io_name","container","instance","job","level","namespace","pod","service_name","mynamespacelabel","cluster","k8s_cluster_name","geoip_city_name","geoip_country_name","geoip_country_code","geoip_continent_name","geoip_continent_code"]
This configuration targets the web-gateway container logs, extracting the ip field, running a GeoIP lookup, and attaching geographic labels such as country and continent names and codes.
This configuration code is responsible for enriching Kubernetes pod logs with geographical information using the Alloy log processing tool. Here’s how it works:
- Filtering logs: The web-gateway container
logsstage.matchline with theselectorspecifies that only logs from the “web-gateway” container will be processed. - Extracting IP address: The
stage.logfmtsection extracts the IP address from the log message. It assumes that the IP address is stored in a field named “ip” within the log. - GeoIP lookup: The
stage.geoipsection performs the actual GeoIP lookup.
- It uses the extracted IP address (
source = "ip") - The GeoIP database file is located at “/geoip/GeoLite2-City.mmdb”
- The database type is specified as “city” (which provides city-level location data)
- Adding geographic labels: The
stage.labelssection adds geographical labels to the log message based on the results of the GeoIP lookup. The labels include:
geoip_country_name: The name of the country where the IP address is locatedgeoip_country_code: The two-letter ISO country codegeoip_continent_name: The name of the continentgeoip_continent_code: The two-letter continent code
Overall, this configuration enriches Kubernetes pod logs with location information based on the IP address found in the logs. This enriched data can then be used for further analysis and visualization in Grafana to understand traffic patterns, user locations, and potential security issues.
Step 4: Verify your enriched logs in Grafana Cloud
Now we’ll walk through how to verify your enriched log data in Grafana Cloud.
After deploying your configuration, logs sent to Grafana Cloud Logs will include geographic metadata. Use Grafana Explore to validate the enrichment:
{container="web-gateway"} |= "ip="
You should now see logs enriched with geographic information, like:
geoip_country_name="Germany"
geoip_country_code="DE"
geoip_continent_name="Europe"
geoip_continent_code="EU"
Step 5: Visualize and act on enriched logs
Lastly, with geographic metadata attached to our logs, we can now create powerful visualizations in Grafana Cloud, such as heat maps and geographic breakdowns. We can even set up alerts on unusual traffic patterns.
By integrating these geographic insights, we can quickly pinpoint and respond to incidents or understand usage patterns in greater detail.
Wrapping up
Combining Grafana Cloud Kubernetes Monitoring with GeoIP lookups empowers teams to achieve richer observability with minimal effort. It helps transform simple logging data into actionable intelligence, improving your operational insights.
Get started today by deploying the Kubernetes Monitoring Helm Chart and leveraging GeoIP to elevate your Kubernetes observability.
You can learn more about the Kubernetes Monitoring Helm Chart in our technical docs. For any feedback or questions, please reach out in our Grafana Community Slack.
