How Istio, Tempo, and Loki speed up debugging for microservices
Antonio Berben is a Field Engineer working for solo.io on Gloo Mesh (with Istio) and Gloo Edge (with Envoy). He is a Kubernetes enthusiast and his favorite quote is: “I will go anywhere, provided it be forward” from David Livingstone. You can find and follow Antonio on Twitter.
“How am I supposed to debug this?”
Just imagine: Late Friday, you are about to shut down your laptop and … an issue comes up. Warnings, alerts, red colors. Everything that we, developers, hate the most.
The architect decided to develop that system based on microservices. Hundreds of them! You, as a developer, think why? Why does the architect hate me so much? And then, the main question of the moment: How am I supposed to debug this?
Of course, we all understand the benefits of a microservice architecture. But we also hate the downsides. One of those is the process of debugging or running a postmortem analysis across hundreds of services. It is tedious and frustrating.
Here is an example:
-Where do I start? You think, and you select the obvious candidate to start with the analysis: app1*. And you read the logs shrinking by time period:*
kubectl logs -l app=app1 --since=3h […]
-Nothing. Everything looks normal. You think, maybe the problem came from this other related service. And again:
kubectl logs -l app=app2 --since=3h […]
-Aha! I see something weird here. This app2 has run a request to this other application, app3*. Let’s see. And yet again:*
kubectl logs -l app=app3 --since=3h […]
Debugging takes ages. There is a lot of frustration until, finally, one manages to figure things out.
As you can see, the process is slow. Quite inefficient. Some time ago, we did not have logging and traceability in place.
Today, the story can be different. With Grafana Loki, Grafana Tempo, and other tools, we can debug things almost instantly.
Traceability: the feature you need
In order to be able to debug quickly, you need to mark the request with a unique ID. The mark is called Trace ID. And all the elements involved in the request, add another unique ID called span.
At the end of the road, you are able to filter out the exact set of traces involved in the request which produced the issue.
And not only that. You can also draw all this in a visualization to easily understand the pieces which compose your system.
How to do this with the Grafana Stack
You are going to do a task simulating a microservices system with a service mesh: Istio.
You will say: Istio offers observability through Kiali.
For observability, Istio relies on Kiali. However, in the world of microservices, we should always show that there are alternatives that could fit the requirements, at least as good as the default ones.
Grafana Tempo and Grafana Loki are good examples of well-done logging and tracing backends. Regardless the performance comparisons, good points to consider are the following ones:
- Tempo and Loki both integrate with S3 buckets to store the data. This relieves you from maintaining and indexing storage that, depending on your requirements, might not be needed.
- Tempo and Loki are part of Grafana. Therefore, it integrates seamlessly with Grafana dashboards. (Let’s be honest here: We all love and use Grafana dashboards.)
Now, let’s see how you can speed up the debugging process with Istio and the Grafana Stack.
This will be your architecture:
Hands on!
Prerequisites
- Kuberentes cluster
- Istioctl. The task was developed with v.1.10
Prepare Istio
You need to have Istio up and running.
Let’s install the Istio operator:
istioctl operator init
Now, let’s instantiate the service mesh. Istio proxies include a traceID in the x-b3-traceid. Notice that you will set the access logs to inject that trace ID as part of the log message:
kubectl apply -f - << 'EOF'
apiVersion: install.istio.io/v1alpha1
kind: IstioOperator
metadata:
namespace: istio-system
spec:
profile: default
meshConfig:
accessLogFile: /dev/stdout
accessLogFormat: |
[%START_TIME%] "%REQ(:METHOD)% %REQ(X-ENVOY-ORIGINAL-PATH?:PATH)% %PROTOCOL%" %RESPONSE_CODE% %RESPONSE_FLAGS% %RESPONSE_CODE_DETAILS% %CONNECTION_TERMINATION_DETAILS% "%UPSTREAM_TRANSPORT_FAILURE_REASON%" %BYTES_RECEIVED% %BYTES_SENT% %DURATION% %RESP(X-ENVOY-UPSTREAM-SERVICE-TIME)% "%REQ(X-FORWARDED-FOR)%" "%REQ(USER-AGENT)%" "%REQ(X-REQUEST-ID)%" "%REQ(:AUTHORITY)%" "%UPSTREAM_HOST%" %UPSTREAM_CLUSTER% %UPSTREAM_LOCAL_ADDRESS% %DOWNSTREAM_LOCAL_ADDRESS% %DOWNSTREAM_REMOTE_ADDRESS% %REQUESTED_SERVER_NAME% %ROUTE_NAME% traceID=%REQ(x-b3-traceid)%
enableTracing: true
defaultConfig:
tracing:
sampling: 100
max_path_tag_length: 99999
zipkin:
address: otel-collector.tracing.svc:9411
EOF
Install the demo application
Let’s create the namespace and label it to auto-inject the Istio proxy:
kubectl create ns bookinfo
kubectl label namespace bookinfo istio-injection=enabled --overwrite
And now the demo application bookinfo:
kubectl apply -n bookinfo -f https://raw.githubusercontent.com/istio/istio/release-1.10/samples/bookinfo/platform/kube/bookinfo.yaml
To access the application through Istio, you need to configure it. It requires a Gateway and a VirtualService:
apiVersion: networking.istio.io/v1alpha3
kind: Gateway
metadata:
namespace: bookinfo
spec:
selector:
istio: ingressgateway # use istio default controller
servers:
- port:
number: 80
protocol: HTTP
hosts:
- "*" # Mind the hosts. This matches all
kind: VirtualService
metadata:
namespace: bookinfo
spec:
hosts:
gateways:
- tracing/bookinfo-gateway
- bookinfo-gateway
http:
- match:
- uri:
prefix: "/"
route:
- destination:
host: productpage.bookinfo.svc.cluster.local
port:
number: 9080
EOF
To access the application, let’s open a tunnel to the Istio ingress gateway (the entry point to the mesh):
kubectl port-forward svc/istio-ingressgateway -n istio-system 8080:80
Now, you can access the application through the browser: http://localhost:8080/productpage
Install Grafana Stack
Now, let’s create the Grafana components. Let’s start with Tempo, the tracing backend we have mentioned before:
kubectl create ns tracing
helm repo add grafana https://grafana.github.io/helm-charts
helm repo update
helm install tempo grafana/tempo --version 0.7.4 -n tracing -f - << 'EOF'
tempo:
extraArgs:
"distributor.log-received-traces": true
receivers:
zipkin:
otlp:
protocols:
http:
grpc:
EOF
Next component? Let’s create a simple deployment of Loki:
helm install loki grafana/loki-stack --version 2.4.1 -n tracing -f - << 'EOF'
fluent-bit:
enabled: false
promtail:
enabled: false
prometheus:
enabled: true
alertmanager:
persistentVolume:
enabled: false
server:
persistentVolume:
enabled: false
EOF
Now, let’s deploy Opentelemetry Collector. You use this component to distribute the traces across your infrastructure:
kubectl apply -n tracing -f https://raw.githubusercontent.com/antonioberben/examples/master/opentelemetry-collector/otel.yaml
kubectl apply -n tracing -f - << 'EOF'
apiVersion: v1
kind: ConfigMap
metadata:
labels:
app: opentelemetry
component: otel-collector-conf
data:
otel-collector-config: |
receivers:
zipkin:
endpoint: 0.0.0.0:9411
exporters:
otlp:
endpoint: tempo.tracing.svc.cluster.local:55680
insecure: true
service:
pipelines:
traces:
receivers: [zipkin]
exporters: [otlp]
EOF
Following component is fluent-bit. You will use this component to scrap the log traces from your cluster:
(Note: In the configuration you are specifying to take only containers which match the following pattern /var/log/containers/*istio-proxy*.log)
helm repo add fluent https://fluent.github.io/helm-charts
helm repo update
helm install fluent-bit fluent/fluent-bit --version 0.16.1 -n tracing -f - << 'EOF'
logLevel: trace
config:
service: |
[SERVICE]
Flush 1
Daemon Off
Log_Level trace
Parsers_File custom_parsers.conf
HTTP_Server On
HTTP_Listen 0.0.0.0
HTTP_Port {{ .Values.service.port }}
inputs: |
[INPUT]
Name tail
Path /var/log/containers/*istio-proxy*.log
Parser cri
Tag kube.*
Mem_Buf_Limit 5MB
outputs: |
[OUTPUT]
name loki
match *
host loki.tracing.svc
port 3100
tenant_id ""
labels job=fluentbit
label_keys $trace_id
auto_kubernetes_labels on
customParsers: |
[PARSER]
Name cri
Format regex
Regex ^(?+) (?stdout|stderr) (?*) (?.*)$
Time_Key time
Time_Format %Y-%m-%dT%H:%M:%S.%L%z
EOF
Now, the Grafana query. This component is already configured to connect to Loki and Tempo:
helm install grafana grafana/grafana -n tracing --version 6.13.5 -f - << 'EOF'
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: Tempo
type: tempo
access: browser
orgId: 1
uid: tempo
url: http://tempo.tracing.svc:3100
isDefault: true
editable: true
- name: Loki
type: loki
access: browser
orgId: 1
uid: loki
url: http://loki.tracing.svc:3100
isDefault: false
editable: true
jsonData:
derivedFields:
- datasourceName: Tempo
matcherRegex: "traceID=(\\w+)"
url: "$${__value.raw}"
datasourceUid: tempo
env:
JAEGER_AGENT_PORT: 6831
adminUser: admin
adminPassword: password
service:
type: LoadBalancer
EOF
Test it
After the installations are completed, let’s open a tunnel to the Grafana query forwarding the port:
kubectl port-forward svc/grafana -n tracing 8081:80
Access it using the credentials you have configured when you installed it:
- user: admin
- password: password
You are prompted to the Explore tab. There, you can select Loki to be displayed on one side and then click on split to choose Tempo to be displayed in the other side:
You will see something like this:
Finally, let’s create some traffic with the tunnel we already created to bookinfo application:
Refresh (hard refresh to avoid cache) the page several times until you can see traces coming into Loki. Remember to add the filter to ProductPage to see its access log traces:
Click on the log and a Tempo button is shown:
Immediately, the TraceID will be passed to the Tempo dashboard displaying the traceability and the diagram:
Final thoughts
Having a diagram which displays all elements involved in a request through microservices increases the speed to find bugs or to understand what happened in your system when running a postmortem analysis.
By reducing that time, you increase efficiency so that your developers can keep working and producing more business requirements.
In my personal opinion, that is the key point: Increase business productivity.
Traceability and, in this case, the Grafana Stack helps you accomplish that.
Now, let’s make it production ready.
The easiest way to get started with Tempo and Loki is on Grafana Cloud. We have free (50GB of traces and logs included) and paid Grafana Cloud plans to suit every use case — sign up for free now.
