Plugins 〉Pyroscope Flamegraph
The Pyroscope Flamegraph plugin has been deprecated and is no longer maintained.
Pyroscope Grafana Panel Plugin
Important: Grafana version 8.0 or later required
Getting started
- Install the plugin (Installation tab)
- Install datasource plugin
- Open Grafana and go to Configuration -> Plugins
- Check that plugins are available
- Set up data source plugin:
- Configuration -> Data Sources -> Add data source
- click on
pyroscope-datasource - Specify Pyroscope host in
Endpointfield
- Set up panel plugin:
- Add an empty panel on your dashboard
- Select
pyroscope-panelfrom Visualization list - Under panel view in Query tab select
pyroscope-datasource - In
Application nameinput specify app name - Click
Apply
Congratulations! Now you can monitor application flamegraph on your Grafana dashboard!
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Pyroscope Flamegraph on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Pyroscope Flamegraph from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.4.2 (2023-03-16)
Bug Fixes
[1.4.1] (2022-11-14)
- support template variables
- Remove broken export button
- Improve flamegraph coloring for go
[1.1.0]
- Add context menu (triggered by right clicking the flamegraph)
- Add toolbar
- Allow focusing on a subtree
- Allow searching nodes that match a specific string
- Visual updates
[1.0.0]
Initial release.
