Plugins 〉Untimely
Untimely
Untimely
Introduction
The Untimely Grafana plugin is a panel that facilitates working with distances on the x-axis (or anything else that isn't time).
You add queries to your visualization, then select the query that represents the x-axis. The different series will then be interlinked based on their timestamps.
It's based on the Grafana React example using Typescript.
Features
- Resets: whenever the x-axis value resets, dropping below a previous value, the graph values keep going
- Legend: the panel has a simple legend, similar looking to the default Grafana legend
- Tooltip: the panel has a simple tooltip, supporting multiple series, similar to the default Grafana tooltip
- Offset: when the x-values have a certain offset, you can define this
Usage and tips
- Use the decimal formatting to choose how many decimals should be in the ticks and on the tooltip
- When you have resets, choose the 'max' selector for your x-axis series and the 'min' selector for the other series
- A little downwards arrow next to a value denotes that there is a reset
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Install on Grafana Cloud
Plugins can be installed directly from within your Grafana instance or automated using the Cloud API or Terraform.
Learn more about plugin installationMarketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Get this plugin
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install Untimely from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
v0.3.1
- Update toolkit to fix issue with missing tslib
- Fix conflicting rules with eslint and prettier
- Fix failing tests
- Introduce provisioning to make easier to develop plugin
- Introduce webpack live reload for provisioned dev env
v0.3.0
Update dependencies and fix panel editor not displaying on Grafana > v8.3.3
v0.2.0
Update dependencies and fix panel editor not displaying on Grafana > v7.3.0
v0.1.0
Initial release
