Plugins
PanelCommunity
Mapgl logo
Mapgl
Vadim Pyatakov
Get plugin
Downloads Project Site Discord Telegram Url ✉️
Start a new panel with a mock node graph to test styles and modes.
Node graph for metrics and traces
  • Layered auto-layout and Geomap view
  • Multistep and parallel edge routing
  • Arc segments on nodes for visualizing multiple metrics
  • TX/RX interface load visualization with dual-metric arcs
  • Ad hoc filtering by layer and node group through the legend
  • WebGL-accelerated rendering for large datasets
  • Dynamic drill-down links to external panels
  • Distributed tracing paths with per-span properties
  • Namespace-based subgraphs
🕹️ Demo
Playground with open configuration
Geomap NodeGraph
Data Format
Dataframe
*Unified dataframe model for nodes and edges. Field names are examples only; Mapgl does not require fixed field names.
See Panel configuration for setup details and dataframe usage.
Data Source
Use Grafana’s built-in transformations to prepare and merge data from:
  • Postgres
  • Prometheus
  • Zabbix
  • Netbox datasource ('Topology edges' query)
  • Infinity (JSON API)
  • Any other datasource
Netbox + Prometheus with drill-down
Netbox to Mapgl automation
Zabbix events on geomap
Field Config
Native Grafana:
  • Thresholds – value ranges with associated colors to visually indicate status
  • Mapping – rename displayed values
  • Units – measurement unit conversion
  • Overrides – custom settings for specific metrics
  • DataLinks – links to external dashboards or graphs
Mapgl Node Group style rules extend control over node color, icon, size, and line width.
Insights
  • Adoption
    Running on 6,789 active Grafana instances.
  • Activity
    Last updated 22 Oct 2026.
    20 releases in the past year.
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
