Plugins 〉Influx Admin
The Influx Admin plugin has been deprecated and is no longer maintained.
Influx Admin
InfluxDB admin
This panel duplicates features from the now depricated Web Admin Interface.
This panel lets you see the currently running queries and easily kill them.
This plugin expects there to be at least one InfluxDB datasource configured.
Screenshots
Building
To complie, run:
npm install -g yarn
yarn install --pure-lockfile
grunt
Changelog
v0.0.5
- Now supports $timeFilter in query
- Now supports datasource defined as a template variable
- Added more debug query templates
- Fix write request bug
- Support Grafana 5+
v0.0.4
- Fix issue always showing query results
- When there is only one row, swap rows/cols (ie: SHOW DIAGNOSTICS)
- Improve auto-refresh behavior.
- Show 'message' response. (ie: please use POST)
- Fix query time sorting
- show 'status' field (killed, etc)
v0.0.3
- Converted to typescript project based on typescript-template-datasource
- Select Databases. This only works with PR#8096
- Added time format options
- Show tags from response
- Support template variables in the query
v0.0.2
- Save the configuration properly
v0.0.1
- First working version
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Influx Admin on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Influx Admin from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
