Plugins 〉XYZ Chart
XYZ Chart
XYZ Chart
The XYZ Chart can be used to plot three-dimensional (or higher dimensional) datasets. 3D plots are useful for a number of applications including geographic plotting, multivariate analysis, and more.
Controls
https://user-images.githubusercontent.com/199847/223649247-580aec80-2182-4c32-bfb9-6f0c91232d76.mov
The XYZ Chart includes typical 3D camera controls so that data can panned, zoomed, and rotated. This allows for straightforward analysis from various perspectives.
Beta
This plugin is currently in beta. Many changes are expected so please pay attention to new versions being released.
Implementation
The chart is built with Three.js via the excellent React 3 Fiber and React 3 Drei. The chart implements a (very) small 3D chart rendering library. We hope to extend this with more chart types in the future.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing XYZ Chart on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
Marketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Get this plugin
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install XYZ Chart from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
0.1.0
Release in Beta.
0.0.1
Initial release.
