Plugins 〉Catchpoint
Catchpoint
Grafana Catchpoint data source plugin
The Catchpoint data source plugin allows you to query Tests, SLO, RUM data.
Project status
NOTE: This plugin is in a public preview. Refer Grafana Labs release life cycle documentation for further details. If you notice any issues or having feature request, create a support ticket with your Grafana Enterprise support channel.
See also
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Catchpoint on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install Catchpoint from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
v0.1.9-preview - 2026-03-03
- ⚙️ Chore: Updated dependencies
v0.1.8-preview - 2026-01-05
v0.1.7-preview - 2025-12-09
- ⚙️ Chore: Update frontend dependencies
- ⚙️ Chore: Minimal supported Grafana version is now
11.6.7
v0.1.6-preview - 2025-10-24
v0.1.5-preview - 2025-02-10
- ⚙️ Chore: Update backend dependencies
v0.1.4-preview - 2024-09-03
v0.1.3-preview
v0.1.2-preview
- ⚙️ Chore: backend binaries are now compiled with go 1.22.5
v0.1.1-preview
- ⚙️ Chore: Update documentation
v0.1.0-preview
- 🚀 Feature: Initial release
