Plugins 〉MapTrack3D
Developer
Theo Hussey
Panel
community
MapTrack3D
  • Overview
  • Installation
  • Change log
  • Related content
MapTrack3D
A plugin for Grafana that visualizes GPS points on a 3D globe. A marker shows the position at the time when hovering over other panels on the dashboard.
Configuration
The plugin requires latitude,longitude, and optionally altitude measurements provided as floats in two/three separate fields formatted by Grafana as a "Time series".
It can be used with MySQL/MariaDB as a data source by using a querie along the lines of:
SELECT
    "timestamp" as time,
    lat,
    lon,
    alt,
FROM test_data
WHERE $__timeFilter(timestamp)
ORDER BY timestamp ASC
A demo CSV file that can be used in conjunction with CSV datasource is provided here
How to develop
If you don’t want to install Grafana on your local machine, you can use Docker.
To set up Grafana for plugin development using Docker, run the following command:
docker run -d -p 3000:3000 -v "$(pwd)"/dist:/var/lib/grafana/plugins --name=grafana grafana/grafana:7.4.3
Since Grafana only loads plugins on start-up, you need to restart the container whenever you add or remove a plugin.
docker restart grafana
Attributions
Icon made by Freepik from Flaticon
Map Texture from Planet Pixel Emporium Copyright (c) James Hastings-Trew
Installing MapTrack3D on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install MapTrack3D from the commandline:
grafana-cli plugins install
Change Log
All notable changes to this project will be documented in this file.
v0.1.3
Initial Release
