This plugin has been deprecated and is no longer maintained.
Single Stat Math Panel
This panel is a modification of the native single stat panel to support math functions across series.
Usage
InfluxDB
To use the math feature, give the series an alias by name and use that name inside the math field as variables.
In the math field you can use the alias names to perform math across series.
Changelog
1.1.6
- Merged PR to fix gauge color
1.1.5
- Merged PR to autoupdate panels with previous threshold format.
1.1.4
- Merged PR to add granular threshold options.
1.1.3
- Merged PR to add circle shape as background option.
1.1.2
- Merged PR to remove importing own flot plugins.
1.1.1
- Changed function evaluation error handling to set results to zero
1.1.0
- Fixed missing flot library crashing graph panel.
- Updated dependencies.
1.0.0
- Added math options if multiple queries are used.
- Math field will use series alias name to evaluate function.
- Version
- 1.1.8
- Developer
- blackmirror1
- Last Updated
- January 19, 2024
