Klag - Kafka Lag Monitoring
Comprehensive Kafka consumer lag and health monitoring for Klag (https://github.com/themoah/klag). Lag, velocity, hot partitions, time-based lag, data-loss-prevention and JVM runtime metrics. Requires a Prometheus-compatible data source.
Klag - Kafka Lag Monitoring screenshot 1
The Klag - Kafka Lag Monitoring dashboard uses the prometheus data source to create a Grafana dashboard with the barchart, bargauge, stat, table and timeseries panels.
RevisionDescriptionCreated
Kafka
Kafka
by Grafana Labs
Grafana Labs solution
Easily monitor your Kafka deployment with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
