Eero Mesh Network
Comprehensive monitoring for Eero mesh networks via Prometheus exporter
Eero Mesh Network screenshot 1
Eero Mesh Network Dashboard
Comprehensive Grafana dashboard for monitoring your eero mesh WiFi network, powered by the eero-prometheus-exporter.
Visualizes 115+ metrics across 15 categories: network status, eero hardware health, connected devices, Ethernet ports, Thread, Eero Plus features, speed tests, data usage, and more.
Dashboard Preview
Variables
VariableDescription
datasourcePrometheus data source (select on import)
network_idFilter by eero network (multi-select, defaults to all)
periodUsage period for data-transfer panels: day / week / month
Requirements
  • Grafana 11.5 or newer (schemaVersion 42)
  • Prometheus datasource scraping the eero exporter
  • eero-prometheus-exporter running and authenticated against your eero account
Setup
1. Install and authenticate the exporter:
pip install eero-prometheus-exporter
eero-exporter login your-email@example.com
eero-exporter serve
Metrics are then exposed at http://localhost:10052/metrics.
Docker users: see the Docker guide.
2. Add a Prometheus scrape job (see Collector Config above), then reload Prometheus.
3. Import this dashboard in Grafana and select your Prometheus datasource when prompted.
Panels
Organized into rows for quick navigation:
  • Network Features — guest network, IPv6, thread, band steering, SQM, captive portal status
  • Network Overview — uptime, gateway health, ISP info, public IP
  • Eero Hardware — per-node status, model, firmware, uptime, LED state
  • Connected Devices — online/offline counts, top talkers, signal strength, connection type
  • Ethernet Ports — link status, speed, duplex per port
  • Speed Tests — download/upload throughput history
  • Data Usage — per-device and per-network transfer by day/week/month
  • Eero Plus — activity tracking, backup network, ad blocking, threat scans
  • Thread Network — device count, network status
  • Exporter Health — scrape success, collection duration, last-update age
License
Apache 2.0
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
