Azure / Insights / Virtual Machines - OpenTelemetry - Default Metrics
Monitors Azure Virtual Machines using OpenTelemetry default metrics collected by VM Insights. Displays CPU utilization (overall, per-core, and by state), memory usage and utilization, disk I/O and operations, file system consumption, and network throughput, errors, and dropped packets. Scoped by subscription, resource group, and VM.
Azure / Insights / Virtual Machines - OpenTelemetry - Default Metrics screenshot 1
Azure / Insights / Virtual Machines - OpenTelemetry - Default Metrics screenshot 2
The Azure / Insights / Virtual Machines - OpenTelemetry - Default Metrics dashboard uses the prometheus data source to create a Grafana dashboard with the gauge, piechart, stat, text and timeseries panels.
RevisionDescriptionCreated
Azure Cosmos DB
Azure Cosmos DB
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
