Menu
Front matter
Grafana technical documentation includes front matter to help organize the content, develop the TOC (as published in the lefthand sidebar of the website), and help users identify useful pages when searching or viewing the content in search engines or in social media, such as Twitter.
Use YAML for all front matter. In certain presentations, all front matter characters might render literally. For this reason, do not include any special Markdown formatting, like italics or monospace, in front matter.
Here’s a correctly built example:
aliases:
  - /docs/mimir/latest/old-architecture/
description: Learn more about Grafana Mimir’s microservices-based architecture.
labels:
  products:
    - oss
keywords:
  - Mimir
  - microservices
  - architecture
menuTitle: Architecture
title: About Grafana Mimir architecture
weight: 100
# About Grafana Mimir architecture
Reference
The following headings describe what each element does and provides guidelines for its content.
aliases
Provides an HTML redirect from the pages in the list to the current page. For more information, refer to Hugo aliases.
description
Required.
On social media, such as Twitter, displays as a clue to users about what the page includes.
The number of characters vary by media, so make the description concise. Provide enough information to guide users to the content by describing what content the link leads to. Often, this doesn’t need to be original prose—you can often scan the first few paragraphs to pluck the appropriate terms or phrases into the description. If it’s too long, it is harmlessly truncated on social media. Use double quotes (") to surround the title. Do not use smart quotes.
draft
When set to true, this option prevents Hugo from rendering the content. Use the command line flag --buildDrafts to generate content marked as draft: true.
keywords
The website uses keywords to link to related pages in the Related content sections. They do not appear in the resulting HTML source for the page and do not affect SEO.
Ideally, use single terms as opposed to phrases.
labels
Use the labels key to add one or more values that you want to appear before the topic title on the published page. Only certain labels are supported.
For labels.products, the supported values and the resulting published labels are as follows:
  • cloud: “Grafana Cloud”
  • enterprise: “Enterprise”
  • oss: “Open source”
Labels can be inherited through cascading front matter. Each project has a set of default labels that are defined in the root _index.md file of the project.
For versioned projects, the _index.md file resides in the website repository. For unversioned projects, the _index.md file resides in the project’s repository.
If the default labels are incorrect for a page or directory of pages, update the labels. Also, if you are adding a new page, consider whether the default labels are appropriate. For each page, include a label in the labels.products sequence for every product that the page relates to.
For example, if a single page describes a feature available in Grafana Cloud and Grafana Enterprise, the source file front matter should include the following:
labels:
  products:
    - cloud
    - enterprise
For a directory of pages that describe a feature only available in Grafana Cloud, the branch bundle _index.md file front matter should include the following:
cascade:
  labels:
    products:
      - cloud
title
Required.
Becomes the document title element. Often browsers display this in the tab for the page.
It doesn’t need to precisely match the menuTitle. Optimize the title for search engines. Use double quotes (") to surround the title. Do not use smart quotes.
If the doc-validator linter has been implemented on your repository, your topic heading must match the title in the metadata.
weight
Determines the placement of the topic within the left-hand sidebar on https://grafana.com. Smaller numbers place the topic higher in the guide. Pages with the same weight have lexicographic ordering.
Use increments of 100 for all other content files. Doing so makes it easier for you to re-order existing topics when you add new topics. Weights are per directory.
Example with different page and menu titles
Description example
On Twitter:
Twitter description
For example:
  • Add a panel using these steps.
  • Understand the configuration options provided by…
  • Learn more about hash rings and their usage
Hugo aliases
Technical writers use Hugo aliases to create redirects to the current page from other URLs.
If you specify aliases in the frontmatter, Hugo creates a directory that matches the alias entry that contains a single .html file.
Example
The following example file intended-url.md contains the alias /original-url within its YAML frontmatter:
aliases:
  - /original-url/
Assuming a baseURL of grafana.com, the auto-generated alias .html file found at https://grafana.com/original-url/ contains something like the following:
<!DOCTYPE html>
<html>
  <head>
    <script>
      const destination = "https://grafana.com/intended-url/";
      console.log(window.location.search);
      document.head.innerHTML = `<meta http-equiv="refresh" content="0; url=${destination}${window.location.search}"/>`;
    </script>
    <title>https://grafana.com/intended-url/</title>
    <link rel="canonical" href="https://grafana.com/intended-url/" />
    <meta name="robots" content="noindex" />
    <meta http-equiv="content-type" content="text/html; charset=utf-8" />
    <noscript>
      <meta http-equiv="refresh" content="0; url={{ safeURL .Permalink }}" />
    </noscript>
  </head>
</html>
The http-equiv="refresh" meta tag attribute, injected by JavaScript, performs an HTML redirect. For more detail about HTML redirects, refer to HTML redirections.
Note: The redirect relies on first party JavaScript support which is common but not necessarily universal.
Guidelines
The correct way to use aliases depends on whether the project is versioned or not.
Unversioned projects
Include an aliases entry that refers to the initial published website directory. Adding an aliases entry makes it safer to move content around as the redirect from old to new page location is already in place. Hugo doesn’t create a redirect .html file when the directory is already populated with content.
Note: The published directory is dependent on which content subdirectory documentation is synced to in the website repository.
For example, documentation synced to a the content/docs directory requires the /docs prefix.
Versioned projects
Do not include an aliases entry that refers to the initial published website directory. The version in the URL path can cause undesirable redirects, such as a redirect from latest content to an old version.
