This is documentation for the next version of Grafana Tempo documentation. For the latest stable release, go to the latest version.
Block format
Tempo stores trace data in Apache Parquet format. Parquet is a columnar storage format that enables efficient querying of specific attributes without reading entire traces.
Why Parquet
Columnar storage is a natural fit for trace data. A TraceQL query like { span.http.status_code = 500 } only needs to read the http.status_code column, not the entire trace. This dramatically reduces the amount of data read from storage. Columnar data also compresses well because values in a column tend to be similar (for example, all service names or all status codes).
Block structure
A block is a directory in object storage containing several files.
FilePurpose
meta.jsonBlock metadata: time range, tenant, block ID, replaces field for atomic replacement
data.parquetTrace data in columnar format
Bloom filtersProbabilistic data structures for efficient trace ID lookups
IndexMaps trace IDs to row groups within data.parquet
nocompact.flgTemporary flag preventing compaction (present during block-builder flushes)
Blocks are stored under <tenant-id>/<block-id>/ in object storage.
meta.json
The meta.json file makes a block visible to the read path. It contains the block ID, tenant ID, start and end timestamps, total number of objects (traces).
A block is invisible to queriers until meta.json exists. The block-builder uses this property to ensure atomicity during flushes.
Schema
Tempo uses a span-oriented heavily nested Parquet schema. Each row represents a span, with columns for intrinsic fields (trace ID, span ID, parent span ID, span name, span kind, span status, duration, start time, root service name, root span name), resource attributes (for example, service.name, deployment.environment), and span attributes (for example, http.method, http.status_code).
Intrinsic fields vs generic attributes
A small number of fields are stored as top-level columns in the schema. These include service.name on resources and status.code on spans. Querying these fields is always efficient because they have their own Parquet columns.
All other attributes (both resource and span) are stored in a generic Attrs column as key-value pairs. Querying these requires scanning the attribute map, which is slower.
Dedicated attribute columns
You can promote frequently queried attributes from the generic column to their own dedicated Parquet columns for better query performance. This is configured centrally in storage.trace.block and applies to all block-producing components (live-store and block-builder). Dedicated columns are assigned dynamically per block based on the configuration at the time the block is built.
YAML
storage:
  trace:
    block:
      parquet_dedicated_columns:
        - name: http.method
          type: string
          scope: span
        - name: deployment.environment
          type: string
          scope: resource
Refer to Dedicated attribute columns for configuration details and recommendations.
Block format versions
Tempo uses versioned block formats.
VersionStatus
vParquet3Deprecated
vParquet4Default and latest in Tempo 3.0
vParquet5Experimental
The block format is configured in:
YAML
storage:
  trace:
    block:
      version: vParquet4
Existing blocks in older formats remain readable. New blocks are always written in the configured version.
Refer to the Apache Parquet schema documentation for the full schema details and the Apache Parquet block format configuration for configuration options.
