This is documentation for the next version of Grafana Tempo documentation. For the latest stable release, go to the latest version.
Configure TraceQL metrics
Caution
TraceQL metrics is an experimental feature. Engineering and on-call support is not available. Documentation is either limited or not provided outside of code comments. No SLA is provided. Contact Grafana Support to enable this feature in Grafana Cloud.
TraceQL language provides metrics queries as an experimental feature. Metric queries extend trace queries by applying a function to trace query results. This powerful feature creates metrics from traces, much in the same way that LogQL metric queries create metrics from logs.
Before you begin
To use the metrics generated from traces, you need to:
- Set the
local-blocksprocessor to active in yourmetrics-generatorconfiguration - Configure a Tempo data source in Grafana or Grafana Cloud ( documentation)
- Access Grafana Cloud or Grafana version 10.4 or later
Refer to the
Metrics-generator configuration documentation for more information about the metrics-generator configuration.
Activate and configure the local-blocks processor
You must enable the local-blocks processor to start using metrics queries like { } | rate().
If not enabled, then the metrics queries fail with the error localblocks processor not found.
Enabling the local-blocks processor can be done either per tenant or in all tenants.
To activate the local-blocks processor for all users, add it to the list of processors in the overrides block of your Tempo configuration.
# Global overrides configuration.
overrides:
metrics_generator_processors: ["local-blocks"]To configure the processor per tenant, use the metrics_generator_processor override.
Example for per-tenant in the per-tenant overrides:
overrides:
'tenantID':
- local-blocksBy default, for all tenants in the main configuration:
overrides:
defaults:
metrics_generator:
processors: [local-blocks]Add this configuration to run TraceQL metrics queries against all spans and not just server spans:
metrics_generator:
processor:
local_blocks:
filter_server_spans: falseTo run metrics queries on historical data, you must configure the local-blocks processor to flush RF1 blocks to object storage:
metrics_generator:
processor:
local_blocks:
flush_to_storage: trueSetting flush_to_storage to true ensures that metrics blocks are flushed to storage so TraceQL metrics queries against historical data.
If you configured Tempo using the tempo-distributed Helm chart, you can also set traces_storage using your values.yaml file.
Refer to the Helm chart for an example.
For more information about overrides, refer to Standard overrides.
Local blocks and metrics-generator in Azure blob storage and Helm
Note
This configuration only applies if you are using a Helm chart, like
tempo-distributed, to deploy Tempo.
By default, the metrics-generator doesn’t require a backend connection unless you’ve enabled the local_blocks processor.
The local_blocks processor is used for generating metrics from traces, which is required for TraceQL metrics
When this configuration is set, the metrics-generator produces blocks and flushes them into a backend storage.
In this case, list the generator in the env var expansion configuration so the STORAGE_ACCOUNT_ACCESS_KEY has the secret value.
You can use this configuration example with Helm charts, like tempo-distributed.
Replace any values in all caps with the values for your Helm deployment.
generator:
extraArgs:
- "-config.expand-env=true"
extraEnv:
- name: <STORAGE_ACCOUNT_ACCESS_KEY>
valueFrom:
secretKeyRef:
key: <TEMPO-TRACES-KEY>For more information, refer to Azure hosted storage.
Evaluate query timeouts
Because of their expensive nature, these queries can take a long time to run. As such, consider increasing the timeouts in various places of the system to allow enough time for the data to be returned.
Consider these areas when raising timeouts:
- Any proxy in front of Grafana
- Grafana data source for Prometheus pointing at Tempo
- Tempo configuration
querier.search.query_timeoutserver.http_server_read_timeoutserver.http_server_write_timeout
Set TraceQL metrics query options
The query_frontend.metrics configuration block controls all TraceQL metrics queries.
The configuration depends on the environment.
Note
The default maximum time range for a metrics query is 3 hours, configured using the
query_frontend.metrics.max_durationparameter.This is different to the default TraceQL maximum time range of 168 hours (7 days).
For example, in a cloud environment, smaller jobs with more concurrency may be desired due to the nature of scale on the backend.
query_frontend:
metrics:
concurrent_jobs: 1000
target_bytes_per_job: 2.25e+08 # ~225MB
interval: 30m0sFor an on-prem backend, you can improve query times by lowering the concurrency, while increasing the job size.
query_frontend:
metrics:
concurrent_jobs: 8
target_bytes_per_job: 1.25e+09 # ~1.25GBSampling and performance optimization
TraceQL metrics queries support sampling hints to improve performance on large datasets. Refer to the TraceQL metrics sampling documentation for more information.
When using sampling in your TraceQL metrics queries, consider:
- Timeout settings: Sampled queries run faster but may still benefit from adequate timeouts
- Concurrent jobs: Sampling reduces per-job processing time, allowing higher concurrency
