Migrate from v1 to v2 storage using Helm
This guide walks you through migrating a Pyroscope installation from v1 to v2 storage architecture using the Helm chart. The migration uses a phased approach that lets you run both storage backends simultaneously before fully cutting over to v2.
For an overview of what changed in v2 and why, refer to About the v2 architecture and Design motivation.
Prerequisites
Before starting the migration, make sure you have:
  • Helm chart version 1.19.2 or later. Verify with:
    Bash
    helm list -n pyroscope -f pyroscope
    Check that the CHART column shows pyroscope-1.19.2 or higher. If your chart is older, upgrade it first.
  • Pyroscope running on v1 storage via Helm. Verify with:
    Bash
    helm get values -n pyroscope pyroscope -o yaml --all | grep -A8 'storage:' | grep -E 'v1:|v2:'
    You should see v1: true and v2: false. If you see v2: true, your installation is already using v2 or is mid-migration.
  • Object storage configured. v2 writes directly to object storage — it doesn’t use local disk for block storage. If you haven’t configured object storage yet, add it to your Helm values. For example, for S3:
    YAML
    pyroscope:
      structuredConfig:
        storage:
          backend: s3
          s3:
            endpoint: s3.us-east-1.amazonaws.com
            bucket_name: pyroscope-data
            access_key_id: "${AWS_ACCESS_KEY_ID}"
            secret_access_key: "${AWS_SECRET_ACCESS_KEY}"
    For other backends (GCS, Azure, Swift), refer to Configure object storage backend. You can also use the filesystem backend, but in Kubernetes, this requires a ReadWriteMany volume that is shared across all pods.
  • kubectl and helm CLI access to your cluster.
Note
The examples in this guide assume Pyroscope is installed in the pyroscope namespace with the release name pyroscope. Adjust the -n namespace flag and release name in helm and kubectl commands if your installation differs.
Migration overview
The migration has three phases:
PhaseWhat happensReversible?
1. Dual ingestv2 components deploy alongside v1. Writes go to both storage backends.Yes
2. ValidateRun both backends for at least 24 hours. Verify v2 data and compaction.Yes
3. Remove v1Remove v1 components. Only v2 serves reads and writes.Partial
The steps below are specific to your deployment mode. Follow the section that matches your installation.
Single-binary mode
Phase 1: Enable dual ingest
In this phase, the single-binary process enables the v2 storage modules alongside v1. Writes go to both storage backends simultaneously, and the read path serves data from both v1 and v2.
Bash
helm upgrade -n pyroscope pyroscope grafana/pyroscope --version 2.0.0 \
  --reset-then-reuse-values \
  --set architecture.storage.v1=true \
  --set architecture.storage.v2=true
The --reuse-values flag preserves your existing configuration. Alternatively, you can pass your values file with -f values.yaml.
Verify Phase 1
After the upgrade completes, check that the pod has restarted and is running:
Bash
kubectl get pods -n pyroscope -l app.kubernetes.io/instance=pyroscope
Check the Helm release notes for migration status:
Bash
helm get notes -n pyroscope pyroscope
You should see output similar to:
# Pyroscope v2 Migration is active
Write traffic will be written to:
- 100% v1: ingester
- 100% v2: segment-writer
Read traffic is served from v2 read path from as soon as data was first ingested to v2.
Also verify:
  • The metastore raft has initialized. Check the pod logs for a message like entering leader state:
    Bash
    kubectl logs -n pyroscope -l app.kubernetes.io/instance=pyroscope --tail=500 | grep -i "entering leader state"
  • The segment-writer ring is healthy:
    Bash
    kubectl port-forward -n pyroscope svc/pyroscope 4040:4040 &
    PF_PID=$!
    sleep 2
    curl -s http://localhost:4040/ring-segment-writer | grep -o 'ACTIVE' | wc -l
    kill $PF_PID
    In single-binary mode, the count should be 1.
Phase 2: Validate v2 is working
Run both storage backends simultaneously for at least 24 hours before proceeding. During this time, you should be able to query data ingested to v2.
Verify data is being written to v2
Query recent profiling data. The v2 read path should serve data ingested after Phase 1. You can use profilecli, the Pyroscope UI, or the API to query profiles from the last hour and confirm results are returned:
Bash
PF_PID=$!
sleep 2
profilecli query series --url http://localhost:4040 --from "now-1h" --to "now"
kill $PF_PID
You should see series labels for the profiling data being ingested. If no results are returned, check the distributor and segment-writer logs for errors.
Verify v2 compaction is running
The compaction-worker compacts segments through the L0 → L1 → L2 levels. Verify that compaction jobs are completing:
Bash
kubectl logs -n pyroscope -l app.kubernetes.io/instance=pyroscope --tail=500 | grep "compaction finished successfully"
You should see log lines like:
msg="compaction finished successfully" input_blocks=20 output_blocks=1
Compaction typically starts within minutes of ingestion, the first block is created once enough segments accumulate for a shard.
Verify error rates are stable
Check that write and read error rates haven’t increased since enabling v2. If you have Prometheus metrics configured:
promql
sum(rate(pyroscope_request_duration_seconds_count{status_code=~"5.."}[5m]))
Error rates should be zero or negligible. Compare against pre-migration baselines to confirm no regression.
Phase 3: Switch to v2 storage
Once you’re confident that v2 is working correctly and you no longer need to query data ingested before Phase 1, you can disable the v1 storage.
Warning
After this step, data ingested before Phase 1 is no longer queryable through Pyroscope. The data still exists in object storage, but the v1 storage modules that serve it will be disabled. Make sure you don’t need to query historical data from before the migration started.
Bash
  --set architecture.storage.v1=false \
Verify Phase 3
Verify that the Pyroscope pod has restarted:
Bash
Verify that queries still return data:
Bash
PF_PID=$!
sleep 2
kill $PF_PID
You should see series labels for recent profiling data. You can also open the Pyroscope UI at http://localhost:4040 and verify that you can query recent profiles. An empty or errored UI indicates a problem — see Rollback.
Microservices mode
If you deployed Pyroscope using the values-micro-services.yaml file as described in Deploy on Kubernetes, follow the steps below.
Phase 1: Deploy v2 components alongside v1
In this phase, you deploy the v2 components (segment-writer, metastore, compaction-worker, query-backend) alongside your existing v1 installation. The distributor starts writing to both storage backends simultaneously. The read path serves data from both v1 and v2.
Bash
helm upgrade -n pyroscope pyroscope grafana/pyroscope \
  --reuse-values \
  --set architecture.microservices.enabled=true \
Verify Phase 1
After the upgrade completes, check that the new components are running:
Bash
Bash
- 100% v1: ingester
Also verify:
  • The metastore raft cluster has elected a leader:
    Bash
    kubectl logs -n pyroscope -l app.kubernetes.io/component=metastore --tail=500 | grep -i "entering leader state"
  • The segment-writer ring is healthy. All instances should show as ACTIVE:
    Bash
    kubectl port-forward -n pyroscope svc/pyroscope-distributor 4040:4040 &
    PF_PID=$!
    sleep 2
    kill $PF_PID
    The count should match the number of segment-writer instances.
Bash
kubectl port-forward -n pyroscope svc/pyroscope-query-frontend 4040:4040 &
PF_PID=$!
sleep 2
kill $PF_PID
Bash
kubectl logs -n pyroscope -l app.kubernetes.io/component=compaction-worker --tail=500 | grep "compaction finished successfully"
Check that write and read error rates haven’t increased since enabling v2. If you have Prometheus metrics configured, query error rates per component:
promql
# Server-side errors by component (distributor, segment-writer, query-frontend, query-backend, etc.)
sum by (component) (rate(pyroscope_request_duration_seconds_count{status_code=~"5.."}[5m]))
All components should show zero or negligible error rates. Compare against pre-migration baselines to confirm no regression.
Phase 3: Remove v1 components
Once you’re confident that v2 is working correctly and you no longer need to query data ingested before Phase 1, you can remove the v1 components.
Warning
After this step, data ingested before Phase 1 is no longer queryable through Pyroscope. The data still exists in object storage, but the v1 read path components (ingester, store-gateway, querier) that serve it will be removed. Make sure you don’t need to query historical data from before the migration started.
Bash
  --reuse-values \
The Helm chart automatically removes v1-only components (ingester, compactor, store-gateway, querier, query-scheduler) when architecture.storage.v1 is set to false, even if your values file or --reuse-values state still contains overrides for those components.
Verify Phase 3
Check that v1 components have been removed and v2 is serving all traffic:
Bash
# v1 components (ingester, store-gateway, querier, compactor, query-scheduler) should be gone
Bash
PF_PID=$!
sleep 2
kill $PF_PID
Rollback
During Phase 1 or Phase 2
Rolling back is straightforward — set architecture.storage.v2=false to remove the v2 components and return to v1-only:
Bash
  --reuse-values \
  --set architecture.storage.v2=false
Data written to v2 during the dual-ingest period is orphaned but doesn’t affect v1 operation.
During or after Phase 3
If you removed v1 components (Phase 3), rolling back requires redeploying them:
Bash
  --reuse-values \
This returns you to dual-ingest mode (Phase 1). Note that any data ingested between Phase 3 and the rollback was only written to v2 and won’t be visible through the v1 read path.
Helm values reference
The following Helm values control the v1/v2 storage configuration and migration behavior.
Storage layer toggles
ValueTypeDefaultDescription
architecture.storage.v1booltrueEnable v1 storage and its components (ingester, store-gateway, querier, compactor).
architecture.storage.v2boolfalseEnable v2 storage and its components (segment-writer, metastore, compaction-worker, query-backend).
Migration tuning
These values only apply when both v1 and v2 are enabled (dual-ingest mode). All values are under architecture.storage.migration.
<prefix>.ingesterWeightfloat1.0Fraction [0, 1] of write traffic sent to v1 ingesters.
<prefix>.segmentWriterWeightfloat1.0Fraction [0, 1] of write traffic sent to v2 segment-writers.
<prefix>.queryBackendbooltrueEnable the v2 query backend for reads.
<prefix>.queryBackendFromstring"auto"RFC 3339 timestamp (e.g. 2025-01-01T00:00:00Z) from which the v2 read path serves traffic. When set to auto, the query frontend consults the metastore per tenant to determine when v2 data first appeared. If no v2 data exists for a tenant, queries fall back to v1.
