Reference data
Reference data lets you store small static datasets directly in your data source configuration. Use this feature to define data once and query it from multiple dashboards without re-entering the same data in each query.
Before you begin
- Ensure you have the Infinity data source installed and configured
- Have administrator access to edit the data source configuration
Use cases
- Store lookup tables for mapping codes to descriptions
- Define static configuration data used across multiple dashboards
- Store small reference datasets that don’t change frequently
Supported formats
Reference data supports the following formats:
- JSON
- CSV
- TSV
- XML
- HTML
Configure reference data
- Navigate to Connections > Data sources and select your Infinity data source.
- Scroll to the Reference data section.
- Click Add Reference Data.
- Enter a unique Name for the reference data (for example,
servers.csvorregion-codes.json). - Enter the data in the Data field using your chosen format.
- Click Save & test.
You can add multiple reference data entries to a single data source instance.
Note
Reference data names must be unique within a data source instance. If duplicate names exist, the first matching entry is returned.
Query reference data
- In the query editor, set Source to Reference.
- Select your reference data from the Reference drop-down.
- Configure the Type to match your data format (JSON, CSV, XML, etc.).
- Set the Format and configure columns as needed.
Provision reference data
You can configure reference data through provisioning:
apiVersion: 1
datasources:
- name: Infinity
type: yesoreyeram-infinity-datasource
jsonData:
refData:
- name: servers.csv
data: |
id,name,region,status
1,server-a,us-east,active
2,server-b,eu-west,active
3,server-c,ap-south,maintenance
- name: regions.json
data: |
{"code": "us-east", "name": "US East"},
{"code": "eu-west", "name": "EU West"},
{"code": "ap-south", "name": "Asia Pacific"}
]Size limits
Warning
Reference data is designed for small datasets of less than 10 MB. Larger datasets may affect Grafana and plugin performance. For larger datasets, use URL-based queries instead.
