Node graph
The Node Graph visualization displays relationships between entities as an interactive graph. Use the Infinity data source to transform your API data into the format required by the Node Graph panel.
For general information about the Node Graph panel, refer to Node graph.
Before you begin
- Ensure you have the Infinity data source installed and configured
- Familiarize yourself with the Node Graph panel requirements
Supported data formats
You can create Node Graph visualizations from the following data formats:
- JSON
- CSV
- XML
- GraphQL
Query structure
A Node Graph visualization requires two queries:
Nodes query
The nodes query defines the entities displayed in the graph.
Required fields
Optional fields
Arc fields
Arc fields create colored segments around the node perimeter. The values must be between 0 and 1, and all arc values for a single node should sum to 1.
To specify colors for arc segments, add a corresponding _color field:
Edges query
The edges query defines the relationships between nodes.
Required fields
Optional fields
Note
Edges do not support arc fields.
Example
The following example creates a simple network visualization with four servers.
Nodes data (CSV)
id,title,subTitle,mainStat,secondaryStat,arc__cpu,arc__memory,arc__cpu_color,arc__memory_color,detail__role
A,Server A,Application Server,12,10,0.1,0.9,blue,red,Frontend
B,Server B,DB Server,90,87,0.1,0.9,blue,red,Database
C,Server C,Application Server,20,23,0.2,0.8,blue,red,Backend
D,Server D,Middleware Server,47,98,0.9,0.1,blue,red,CacheEdges data (CSV)
id,source,target,mainStat,secondaryStat,detail__protocol
1,A,B,30,mb/s,TCP
2,A,C,20,mb/s,HTTP
3,B,D,24.2,mb/s,TCPQuery configuration
Query A (Nodes):
- Set Type to CSV.
- Set Source to Inline and paste the nodes CSV data.
- Set Format to Nodes - Node Graph.
- Configure columns to map CSV fields to node graph fields, ensuring numeric fields use the
numbertype.
Query B (Edges):
- Set Type to CSV.
- Set Source to Inline and paste the edges CSV data.
- Set Format to Edges - Node Graph.
Column mapping
When your source data uses different field names than the Node Graph format requires, use column aliases to map them.
Note
For CSV data, explicitly set numeric columns to the
numbertype. Otherwise, they render as strings and may not display correctly.
JSON example
For JSON data, configure the root selector to extract the array of nodes or edges:
Nodes query:
"nodes": [
{ "id": "A", "title": "Server A", "arc__cpu": 0.3, "arc__memory": 0.7 },
{ "id": "B", "title": "Server B", "arc__cpu": 0.8, "arc__memory": 0.2 }
}Set the root selector to nodes and the format to Nodes - Node Graph.
Edges query:
"edges": [
{ "id": "1", "source": "A", "target": "B", "mainStat": "100 req/s" }
}Set the root selector to edges and the format to Edges - Node Graph.
