Slide 7 of 8
Configure Prometheus remote write
Learning path: Prometheus remote write
Learning path
Send metrics using Prometheus remote write
Welcome to the Grafana learning journey that provides the best practice for configuring Prometheus remote write to send metrics to Grafana Cloud.
11 min
Beginner
Docs & blog posts
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack, or in the Grafana Play stack, with an interactive learning experience.
Script
Time to put what you’ve learned into practice. This learning path walks you through configuring Prometheus to send metrics to Grafana Cloud using remote write.
You’ll verify your Prometheus setup, configure the remote_write block with your Grafana Cloud credentials, and confirm that metrics are flowing to Mimir.
By the end, you’ll have Prometheus sending metrics to Grafana Cloud and be able to query them in Grafana.
Work through each milestone in order. When you’re done, click Complete Path to continue.
