Slide 8 of 8
Level 3 deep dives
Ready to go deeper?
CourseDescriptionStatus
Distributed tracingSpan analysis, trace-to-logs, bottleneck detectionFuture
Traces drilldownExplore traces without writing TraceQLFuture
Continuous profilingFlame graphs, CPU/memory optimizationFuture
Frontend observabilityCore Web Vitals, session replay, RUMFuture
AI/LLM observabilityToken tracking, prompt analysis, GPU monitoringFuture
Operational practices for Level 3
Transaction alertingLatency alerts, trace-based investigationFuture
Transaction SLOsEnd-to-end latency targetsFuture
Trace dashboardsSpan breakdowns, latency distributionsFuture
Incident responseOnCall, Incident, Sift AIFuture
Documentation
Once you can debug individual transactions, Level 4 lets you add custom business insights.
Script
Level 3 has a lot of surface area, so there are several deep dive courses to choose from.
For the core capabilities, we’re building courses on Distributed Tracing, Traces Drilldown (which lets you explore traces without writing queries), Continuous Profiling, Frontend Observability, and AI/LLM Observability.
On the operational side, there’s Transaction Alerting, Transaction SLOs, and Trace Dashboards.
Check the documentation links on this slide if you want to start exploring these features now. The docs are comprehensive.
Once you can confidently debug individual transactions and understand exactly where time is being spent, you’re ready for the final level: adding custom insights through manual instrumentation.
