Slide 10 of 10
Level 1 deep dives
Ready to go deeper?
Status refers to course availability, not product availability. All products listed are available in Grafana Cloud today.
CourseDescriptionStatus
Introduction to integrationsPre-built monitoring for 100+ technologiesAvailable
Introduction to data sourcesConnect to existing monitoring toolsAvailable
Introduction to Cloud Provider ObservabilityAWS, Azure, GCP monitoringAvailable
Send data from external collectorsPush metrics/logs via Prometheus, OTel, HTTP APIAvailable
Database ObservabilityMySQL, PostgreSQL, MongoDB monitoringCourse coming soon
Kubernetes MonitoringClusters, pods, workloads, cost analysisCourse coming soon
Fleet managementManage Alloy collectors at scaleCourse coming soon
Explore your dataDrilldown apps for metrics and logsCourse coming soon
Operational practices for Level 1
Infrastructure alertingHost alerts, routing, investigationCourse coming soon
Infrastructure SLOsUptime targets, error budgetsCourse coming soon
Infrastructure dashboardsPre-built and custom dashboardsCourse coming soon
Once you have infrastructure visibility, you’re ready for Level 2.
Script
If Level 1 is where you need to focus, here are the courses that will get you there.
For getting data into Grafana Cloud, we have courses on integrations. That’s your fastest path to monitoring common technologies. We have Data Sources if you want to connect to existing monitoring systems.
Cloud Provider Observability covers AWS, Azure, and GCP. Database Observability helps you monitor MySQL, PostgreSQL, and other databases. Kubernetes Monitoring gets you full cluster visibility.
Send Data from External Collectors shows you how to push metrics and logs from Prometheus, InfluxDB, or other collection tools you’re already running.
Fleet Management teaches you to manage Grafana Alloy collectors at scale.
And Explore Your Data shows you how to use the Drilldown apps to investigate metrics and logs without writing queries.
On the operational side, we’re planning courses for Infrastructure Alerting, SLOs, and Dashboards.
Take a look at what’s available, pick the one that matches your immediate need, and dive in. Once you’ve got solid infrastructure visibility, you’ll be ready to level up.
