Slide 8 of 10
Kubernetes Monitoring overview
Full cluster-to-pod visibility for container orchestration
LevelWhat’s monitoredKey metrics
ClusterControl plane, etcd, API serverAvailability, latency, pressure
NodesKubelet, node resourcesCPU, memory, disk per node
PodsContainer resources, restartsRequests vs. usage, OOM kills
WorkloadsDeployments, StatefulSetsReplica availability, rollouts
NetworkingServices, Ingress, DNSRequest rates, latency, errors
Out-of-the-box capabilities
Kubernetes Monitoring capabilities showing dashboards, alerts, cost management, and ML predictions
Questions answered
With Kubernetes Monitoring, you can answer…
Which pods are using the most CPU in my cluster?
Why did this pod crash? What were the logs before the OOM kill?
How much is my infrastructure costing, and where can I save?
What will my resource usage look like next week?
Which namespace is consuming the most resources?
Problems solved
ProblemSolution
Complex manual setupHelm chart deployment, no manual config
No visibility into pod resourcesComplete cluster-to-container metrics
Hard to debug pod crashesCorrelated logs, metrics, and automated diagnostics
Unpredictable costsBuilt-in cost views and savings recommendations
Capacity planning guessworkML-powered CPU and memory predictions
Script
If you’re running Kubernetes, you know how complex it can get. Pods restart, nodes get scheduled, and deployments roll out. Without visibility, debugging is a nightmare.
Kubernetes Monitoring is a dedicated application in Grafana Cloud that gives you complete visibility with almost no setup. You deploy using a Helm chart, and that’s basically it. No manual configuration of agents, no building dashboards from scratch.
What makes it powerful is everything that comes out of the box. You get a unified view from cluster down to individual containers. You get built-in alerts and runbooks for common issues.
You get cost visibility: see exactly what your infrastructure is spending and where you can save.
You even get ML-powered predictions for CPU and memory, so you can plan capacity before you run out.
The app also integrates with other Grafana Cloud tools. You can jump from a problem pod directly to Application Observability to see trace data, or launch automated diagnostics to help identify root cause.
It turns Kubernetes from an opaque system into something you can actually understand and optimize.
