- Documentation
- Learning Hub
- Module 4 of 4 Wrap-up
Key takeaways
Slide 3 of 5
What you learned
Fleet Management = Central control for all your collectors
Collectors register with
remotecfgblock and appear in inventoryConfiguration pipelines remotely configure without touching machines
Attribute matching targets pipelines to specific collector groups
Local + remote configs run in parallel, isolated from each other
Force multiplier for Level 1 that makes existing capabilities scale
The core workflow
What to do next
- Expand your fleet — Register more collectors as you deploy them
- Create pipelines — Build configs for your specific monitoring needs
- Refine attributes — Adjust your schema as patterns emerge
- Explore dashboards — Use health data to catch issues early
