Slide 14 of 14
Fleet meaningfully categorized!
What you accomplished
  • Navigated to Fleet Management and selected collectors
  • Assigned team attributes to identify collector ownership
  • Assigned service.name attributes to identify monitored services
  • Assigned env attributes to identify deployment environments
  • Used bulk edit to apply attributes across multiple collectors
Skills unlocked
SkillWhat you can do now
Fleet categorizationOrganize collectors with meaningful attributes
Attribute assignmentSet remote attributes in the Fleet Management UI
Bulk operationsApply attributes to multiple collectors at once
Categorize once, target precisely. Attributes are the foundation for remote configuration at scale.
Script
Excellent work! You’ve just completed your second learning path and unlocked the skill that makes remote configuration possible at scale.
You navigated to Fleet Management, selected collectors, and categorized them with three key attributes. You assigned team to identify ownership, service.name to identify what each collector monitors, and env to identify where it runs. You used the bulk edit tool to apply attributes across multiple collectors at once.
Now every collector in your fleet answers three critical questions: who owns it, what service does it support, and where is it running. That’s the foundation for everything that comes next—when you create configuration pipelines, these attributes are how you target them.
With this skill, organizing your fleet doesn’t get harder as it grows. It stays manageable.
