Slide 13 of 14
Categorize your collector fleet
Learning path
Categorize a collector fleet
Welcome to the Grafana Fleet Management learning journey that shows you how to organize and categorize your collector fleet using custom attributes for remote configuration. Learn to categorize your infrastructure with meaningful attributes that answer critical questions such as who owns this collector, which service does it support, and where is it running.
9 min
Intermediate
Docs
Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack, or in the Grafana Play stack, with an interactive learning experience.
Script
Now it’s time to organize your collector fleet with meaningful attributes. This path will walk you through categorizing your collectors step by step.
You’ll start with a quick context slide on why fleet categorization matters—attributes give you the foundation for remote configuration management and operational organization.
Then you’ll navigate to Fleet Management, select collectors, and assign three key attributes: team to identify ownership, service.name to identify which service a collector monitors, and env to identify the deployment environment. You’ll use the bulk edit tool to apply attributes across multiple collectors at once.
By the end, every collector in your fleet will answer three critical questions: who owns it, what service does it support, and where is it running.
Work through each milestone in order.
