Slide 12 of 14
Safe experimentation workflow
  1. Create pipeline
  2. Set matcher for ONE test collector (e.g., collector.ID=“test-collector-01”)
  3. Activate and verify
  4. Expand matcher to small group (e.g., env=“staging”)
  5. Verify at scale
  6. Expand to full target (e.g., env=“production”)
The confidence equation
Isolation + Fallback + Instant rollback + Targeted testing = Safe to experiment
You’re not gambling with production. You’re making controlled changes with multiple safety nets. Start small, verify, expand.
Coming up next
You’ll categorize your collector fleet in the learning path. You’ll assign attributes like team, service.name, and env—the foundation that makes targeted configuration and safe rollouts possible.
Script
Now that you understand the safeguards, let’s talk about the workflow that takes advantage of them. This is how you should approach any new pipeline.
Start by creating your pipeline and setting a matcher for just ONE test collector. Maybe use the collector ID directly, or create a test attribute. Activate the pipeline and verify it works—check that there are no errors, that performance is acceptable.
Once you’re confident, expand the matcher to a small group. Maybe all staging collectors, or a specific team’s collectors. Verify again at this slightly larger scale.
Only then do you expand to your full target—production, all regions, whatever your goal is.
This is the confidence equation: isolation plus fallback plus instant rollback plus targeted testing equals safe to experiment. You’re not gambling with production. You’re making controlled changes with multiple safety nets.
If something goes wrong at any step, deactivate and try again. That’s the power of this approach—recovery is fast and doesn’t require deployments or restarts.
Before you create your first pipeline, though, you need collectors organized with the right attributes. That’s what you’ll do next.
