- Documentation
- Learning Hub
- Module 3 of 4 Remote configuration
Attribute matching
Slide 8 of 14
Attribute matching
Attribute matching is the mechanism that connects pipelines to collectors. When you create a pipeline, you define matchers, which are rules that specify which collectors should receive that pipeline based on their attributes.
Matchers determine which collectors receive a pipeline.
How matchers work
Matcher syntax
Matching rule: AND logic
All matchers must match for a collector to receive a pipeline.
