Slide 6 of 8
Self-monitoring
Self-monitoring pipelines
Self-monitoring pipelines are configuration that Fleet Management automatically assigns to each registered collector, instructing it to collect and report its own health data.
Self-monitoring: observability for your observability
Why self-monitoring matters
Without self-monitoring, you’d have a blind spot with no visibility into whether your collectors themselves are healthy.
ScenarioWithout self-monitoringWith self-monitoring
Collector runs out of memoryYou don’t know until metrics stop arrivingYou see memory usage climbing
A component failsSilent failure, missing dataComponent dashboard shows it’s unhealthy
Collector is overloadedData arrives late or not at allThroughput metrics show the issue
You don’t have to configure this. It’s automatic. Self-monitoring is observability for your observability.
Script
API calls, alerts, and configuration errors tell you if your collector is operational, but they’re not the only ways to monitor your collectors.
Self-monitoring pipelines are configuration that Fleet Management automatically assigns to each collector. They tell the collector to monitor itself—to collect its own CPU usage, memory consumption, component health, and internal logs—and send that data to Grafana Cloud.
Here’s why this matters. Imagine your collector is running on a server, collecting metrics from your applications. But what if the collector itself starts having problems? Maybe it’s running out of memory, or a component is failing. Without some way to monitor the collector itself, you’d have a blind spot. You wouldn’t know there was a problem until your metrics stopped showing up.
Self-monitoring pipelines eliminate that blind spot. When you register a collector with Fleet Management, these pipelines get assigned automatically. The collector immediately starts collecting its own health data and sending it to Grafana Cloud. That data powers the health dashboards you see in Fleet Management.
Here’s the key point: you don’t have to configure anything. Self-monitoring happens automatically when you register a collector. The health data just starts flowing.
Now it’s time to put these concepts into practice. In the next slide, you’ll complete a hands-on learning path where you’ll register a collector with Fleet Management and explore the health monitoring features firsthand.
