- Documentation
- Learning Hub
- Journey Database Observability
- Section 4 of 4 Wrap up
Key takeaways
Slide 3 of 5
What you learned
Two approaches to database monitoring, each for a different need:
How to choose:
- Database supported by DB Observability? → Use it for the deepest visibility
- Not supported? → Use an integration for infrastructure monitoring
Key details:
- Database Observability supports managed databases (RDS, Aurora, CloudSQL, Azure) for MySQL and PostgreSQL
- Integrations use Grafana Alloy with built in exporters. Most set up in 15–20 minutes.
- These approaches are complementary. Use Database Observability for MySQL and PostgreSQL, and integrations for other databases in the same environment.
The one thing to remember
Start with Database Observability for MySQL and PostgreSQL. It gives you the deepest visibility. For other databases, use integrations.
