Slide 1 of 10
Database integrations
What you learned in Database Observability
  • Deep query-level monitoring for MySQL and PostgreSQL
  • How Grafana Alloy collects query performance, explain plans, and wait events
  • When Database Observability is the right choice for your database
What you’ll do in this section:
  • What integrations provide — Metric collection, pre-built dashboards, and alerting
  • MongoDB — Operations, connections, replication, and memory monitoring
  • Redis — Commands, memory, keyspace, and persistence monitoring
  • Memcached — Hit rate, evictions, memory, and connection monitoring
  • Cassandra — Reads, writes, compaction, and JVM monitoring
  • MySQL and PostgreSQL — Basic metric monitoring as a fallback when Database Observability isn’t an option
  • Oracle Database — Sessions, processes, tablespaces, and wait-event monitoring
Choose one database to set up hands-on, or explore multiple.
Estimated time
10–15 minutes (concept slides) + 15–20 minutes (hands-on learning path)
Script
In the previous section, you explored Database Observability, Grafana Cloud’s deepest approach to monitoring MySQL and PostgreSQL. Now it’s time to look at a broader option.
Database integrations use Grafana Alloy to collect infrastructure-level metrics from a wider range of databases, including MongoDB, Redis, Memcached, Cassandra, and Oracle Database. Each integration ships with pre-built dashboards and alerts, so monitoring starts working right away.
In this section, you’ll see what integrations provide, compare the options, and then choose a database to set up hands-on.
