- Documentation
- Learning Hub
- Journey Database Observability
- Section 1 of 4 Journey overview
How to choose
Slide 4 of 7
Start with your database technology
The right approach depends on what database you’re running and what you need to see.
Decision framework
- Is your database MySQL or PostgreSQL? → Start with Database Observability. It gives you the deepest visibility available.
- Is your database supported by an integration? → Use an integration. You get health metrics, pre-built dashboards, and alerts with minimal setup.
Managed databases are supported
Database Observability works with the following self-managed databases and managed cloud services:
- Amazon RDS and Aurora
- Google Cloud SQL
- Azure Database for MySQL and PostgreSQL
