What you learned
Data sources connect Grafana to external systems: query, visualize, and create alerts on data where it already lives
Common data sources by use case:
- Metrics: Prometheus, InfluxDB
- Logs: Loki, Elasticsearch
- Cloud: CloudWatch
- Application data: MySQL, PostgreSQL
- Flexible: Infinity, Google Sheets
The critical trade-off:
- Data Sources = Query, visualize, alert (same alerting engine as integrations; some include pre-built dashboards)
- Integrations / Send Telemetry = Full Grafana Cloud features (ML insights, SLOs, correlations)
The one thing to remember
Data sources let you query, visualize, and alert. Same alerting engine, same dashboarding capabilities. The trade-off: data stays external, so you won’t get ML-powered insights, SLOs, or cross-signal correlations.
